Can't get viaccess card to work with freecam
blackninja
I'm trying to get a programmed viaccess gold card to work with my irdeto mascetti 2.018 freecam. I've tried switching EMU off and switching to viaccess and the I/V/B/N/S option (it says something like that). The card's inserted into the cam with the chip facing downwards. What's going wrong? Are they compatible?
blackninja
I'm on hotbird and I'm after Zik/XXL, Multivision, Prem Footy and maybe BBC Prime. The card came from ebay and judging from the guy's feedback I've no reason to doubt that it works.
loftyj said:
What satellite and what channels are you after
loftyj
First thing to do is check if your patched cam can open TPS and ABsat, thay both use multi encriptions.
Burnham Beech
The viaccess gold card does not work in an irdeto freecam. You need 6in1 funcard or silvercard.
Whether it works or not with some TPS channels will depend on the receiver. With the right receiver the 2018 freecam will open all currently hacked channels.
The cards are inserted into cams chip contacts up.
try to flash new bin 2020 work fine my freecam on topfileld
blackninja
You mean it works with a viaccess gold card having done this?
I'm struggling with 6 in 1 files as funprom 3.0 won't seem to program my funcard 6 using an apollo programmer. Thinking of forking out on an elvis programmer. Will that do titanium as well as funcard/silvercards?
Burnham Beech
A viaccess gold card will not work in an Irdeto freecam whatever the freecam version.
The elvis programmer will easily program titanium cards.
What cam were you intending to use the titanium in? Titanium cards do not work in an Irdeto freecam.
