- May 29, 2009
- North York Moors
"Cannot" is a bit strong, but it is true to say the results will depend upon the skill of the installer to a large extent.
The shape, for example, is unlike proper dishes and the Sky LNBs have a feedhorn shaped that matches the unique dish shape.
So, if you hang some sort of offset LNB on it, which would probably be a proper Universal LNB, there will be reduced efficiency and a lot of fiddling would be required.
It depends as well upon the separation angle and the strength of the signal from the target Satellite on the offset etc.
