combined 4core and sat coax in 1 cable
W
wod
yorkshire
in my planning to upgrade to 36volt motor i will need a run of motor cable and sat coax so is the combined cable any good ?
how does it work as can you split the cable as the motor will be behind the dish as the sat coax will need to run to the lnb
using the combined cable will save having to drill an extra hole
or should i run two separate cables to the motor and lnb ?
thanks
wod
You will still need to enlarge the hole you already have, so you may as well run a separate cable. :)
W
wod
yorkshire
well i was planning to use the existing cable for a sky digibox as i'm going to put the dish higher up cause of bloody trees
rolfw how wide is the combined cable is it more than 10mm ?
also could you recommend a place to buy a 50m reel of wf100 and 4 core cable ?
Not sure of the dimensions wod, probably 12mm or so, you could try Grax.co.uk, they are wholesalers, but will be able to put you onto a supplier.
johnsattuk
johnsattuk
Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
West Mids, UK
I did post a pic of my shotgun combined cable, it is 13.8mm wide x 6.8mm thick :)
W
wod
yorkshire
hmm dont want to drill a hole that big so maybe best to drill 2 holes next to each other and use one of them cable hole tidys i have spare
W
wod
yorkshire
what size is the twin webro wf65 as now fancy installing some of this instead for future proofing with separate motor cable feed
T
timbo86
Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn.
Belfast, Northern Ireland
The shotgun cable we use for sky installs fits through a 10mm hole.
W
wod
yorkshire
hmm thats good also does it fit through those cable hole tidys ?
