conax gone again??
adrianmac
does m2 card work on a matrix rev cam?
how much will one cost
plse help
psats
plse help
My card works in my embeded force cam and reloaded cam so should work on the rev
the cost is around £30
adrianmac
thankyou where could i purchase and could i use my dynamite programmer to program it
do you know hoe to change the codes in the mat rev ie can u get channels on it without a card
shazmart
Technomate 5500ci plus
Motorised dish
Infinity Phoenix programmer
Blue Tit /MkII/Various Fun cards...& a Matrix Reloaded cam
Norfolk
mehran666 said:
hi shazmart
how are you
Hi...i`m pretty good, as i think i`ve almost mastered the `conax/tit`thing, i reckon it`s time to branch out a bit. Maybe try and find out what other encryption systems are out there and what they do....
..."i`ll be back"!!!
Razor
Retired Mod
Ireland
You can buy a fun4 or fun6 card for £10 or less.
I get all TPS, XXL and most Via1 channels on a fun4 card.
adrianmac
will thses work razor on mat rev cam?
hellpic
Home
I've got Magic Module and it works fine with funcard (6 in1)... Mat rev cam even better... I think you can even change keys with remote control and open channels without card...
palto
I am a new member.
can anyone tell me how can I upgrade my digital box keys?
I have *sat ECI9500S and it has Materix cam.
I dont know on whitch website I can find new keys.
palto
can anyone tell me where can I download keys for Materix cam?
Mickha
North West
Hi palto,
you can try here:
_http://www.sat-key.org/
Click on the Cams files link in the left hand pane and then on your cam. For keys try the other links.
Best wishes
Mickha
BEYAZ
conax gone waiting for new keys any one confirm
season greatings
sajithaz
can somebody tell me how can i activate remote key option in technosat1100
richynysmon
season greatings
Working at 7.30am this morning news keys where available last night after change
Rich
mholali
Looks like M2 cards are the hot cakes on the market for conax. The new files were posted on the web minutes after conax went down yesterday. And i mean minutes. Many thanks to TeamPDK. Conax keys for dragon do not come out till 3 or 4 days later. Was in the middle of watching chicago when it went off. I would definately recommend it. £35 for one. Bought it last saturday. Money well spent so far. Works brilliant with my dragon cam + technomate 5500CIP + 100cm Motorised dish.
Cheers!
Marty
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
... or £21.50 from unapit. :)
