conax problem!
nordy250
i have updated by t*tanium card with the new c*nax files. I can see the channel which i unlock immediatly, but when going through the chanells my box keeps stalling and the picture just freezes, any advice?
nordy250
can someone tell me what version of mr they are using and what version of t*tanium card they are usind to see c*nax properly. I can view a channel for 15 mins and then it will just say, channel scrambled.
I am using matrix reloaded version 1.071, should that work or should I upgrade to a newer version.
Please help!!!!
Sorry , Ive only the Conax Cam, all OK here, but I dont normally change channels fast, as theres often something worth watching on (unlike the local satellite broadcaster)
Razor
Retired Mod
Ireland
Same here I have an EMB conax slot, but the card is working fine. Maybe if you go to a FTA channell and turn of your box , wait a min or so and back on again. This might help the MR to settle down.
markse
Tjörn, Sweden
I sort of have the same problem.
I'm trying to view co**ax through a titanium card (v1.06).
But my box hasn't got inbuilt co**ax only via***s.
I have two cam slots at the front of the box, what cam reader should I use that is compatible with the titanium card?
I've seen a Conax CA-Modul, would anyone know if this would work?
Cheers
The Fatty
Fortec Star Passion HD
Nokia 9600S (DVB2000)
Skystar 2
Devon
Can you get conax on progDVB? do they have the correct softkeys for it yet?
