Connect a Lumax box and Dish
Likes
Lumax box and 1.4m dish and need help
Russia (Moscow)
#1
Hi I am living in Moscow and have just moved into a flat which has a 1.4m dish set up and connected to a Lumax box which receives all Turkish channels!
My question in can i change this connect and recieve other satellite channel possibly English, at least the ones which will have all the football on!
What process do i need to install new channels?
thanks for your help everyone
Ste
Robbo
Likes
5
Gravesend,Kent,UK
#2
It depends on which satellite your dish is pointed at for what channels you can get.
Hotbird13E has the Art sport package on it for which you need a card.
Polsat also has sports channels, but possibly not in English plus decoding equipment required.
Which Satellite is your dish pointed at?
Likes
Russia (Moscow)
#3
Hi, currently the satellite is pointed at Turksat 1a or 1c! I try to search other satellites on the system but i dont know how to connect or whether it is in the right place
Robbo
Likes
5
Gravesend,Kent,UK
#4
Turksat is at 42 degrees east.
Unless you point your dish at a different satellite you will not be able to 'search' other satellites.
To align your dish with hotbird 13E you would need to rotate the dish to the left (looking at front of dish) by 34 degrees, and tip it down by 3.5 degrees.
Also the LNB will need rotating anticlockwise by 19 degrees.
Useful info here _http://www.satsig.net/maps/lat-long-finder.htm
and here _http://www.lyngsat.com
To make life easier a cheap satellite meter (cost approx £10 UK) so that adjustment can be made.
Your dish should be large enough for Hotbird.
Probably a good idea to user a marker pen to mark your dish's current settings so you could go back to them if you have a problem.
Likes
Russia (Moscow)
#5
thanks for your help i'll give it a try tonight
