connecting Monoblock and single LNB
dave branson
Florence Italy
I am going to set up 16deg /e LNB to receive Digialb,to do this is a bit
confusing,as I have 13/19 deg monoblock with disq switch, for Hotbird and Astra.
Is it possible to install a 2x1 disq switch in line,or should i install 3 separate LNB,s with a 3x1 disq switch
As long as you use a committed switch, which most of the cheaper ones are and can enter two stage commands in your receiver, then it should work.
