ct100 and ft100 cable ??
iwol
Likes
16
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
#1
hi ive just found ive got a big loss in my cable run i see maplins sell ft100,but everyone seems to recomend ct100 does anyone know the difference thanks iwol
wod
Likes
235
yorkshire
#2
how much cable run have you got as wf125 or ct125 is much better cable for long cable run if its below 30metre use some wf100 cable
Likes
3,418
Can't say I've noticed any difference (I've used both). Same specification. May be better to use a higher spec cable (CT/FT125) if you have a long run.
iwol
Likes
16
satlook micro
yorkshire
#4
its about 20-25metres i think but im losing about 30 percent from dish to receiver ive got a 1.2m cm so i pick most things up ok im just trying to squeeze the last drop out,what drop difference starts to make a difference especially on the low power sats
Snuffer
Likes
Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Amsterdam
#5
If you can find short peices of cable see of you can find this.
http://www.romal.com/html/coax/html/CATV%20satteliet/PRG%2011%20CU%20PVC.pdf
Best coax there is we use only this and never problems and LOW LOSS
iwol
Likes
16
satlook micro
yorkshire
#6
where would i get the prg11 cable from snuffer as it seems to have less loss than the ct100
wod
Likes
235
yorkshire
#7
ct100 or h109f what it is called now is rubbish well not rubbish just used on sky systems
you want to change it to some proper good cable like wf100 or wf125 or even rg6 not the ally foil version the proper copper on copper stuff used
satcure sells WF125 cable in 100m reel for 60 quid _http://www.satcure.co.uk/accs/page8.htm#WF125
rolfw and other members can advise more
iwol
Likes
16
satlook micro
yorkshire
#8
so is ct125 same as wf125 and whats the outer diameter thanks
Likes
1,288
#9
For 20m you shouldn't really need anything bigger than WF100 or CT100. With the huge loss that you mention in the other thread, it is more likely to be a defective cable, or a bad meter reading. The difference in loss over 20m between WF100, made by Belden and the Belden G11 1.55mm core cable mentioned above, would only be a couple of DB at the highest frequency, and I doubt if your installation is that critical.
iwol
Likes
16
satlook micro
yorkshire
#10
cheers guys gonna go out now and recheck meter reading while its not raining
iwol
Likes
16
satlook micro
yorkshire
#11
just checked 102.2 at lnb and 88.9 bfore the diseque switch behind tv does this sound better
Likes
1,288
#12
Yes, quite a bit. :)
