DCC connection problem
R
redout
1M Dish with Motek 2100,
DM 500 & DM 800HD, Vu+ Duo,
Digital+, Sky+, TDT, Saorview
Dublin
Just at to installing Dreambox Control Centre DCC on my laptop and at to running the programme which is in german! says it is not connected. I currently have my Dream 500s connected to my router and the router to the laptop. Do I need to connect the Dreambox directly to the laptop via the Ethernet cable for this to connect or am I doing something wrong ?
Thx
B16MCC
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
you have to tell DCC that you're using a router. You also have to tell it the IP address of the DM. You can select the language from a dropdown box if I remember correctly.
R
redout
Dublin
Thats brilliant. I done that and it recognises the Dreambox but now it wants my router IP ? How do I get that or is it just 192.168.1 by default ?
EDIT: Found it
R
redout
Dublin
Had DCC working yesterday but today I have gone into and keep getting "Error 10057 in function send socket is not connected". There is a green line from computer to router but line to the router is red. Any help appreciated.
R
redout
Dublin
Messag on DCC is saying check dreambox IP. When I go into Norton it is telling me the dreambox is offline. It also tells me I have several other devices all offline that are sharing the same IP address 192.168.1.102
