DD DIRECT DTH using TATASKY Receiver
B
barathm
TATASKY
India
Is it possible to receive DD DTH using TATASKY Receiver ?
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
INDIA
If you Receiver is ready to add TPs, Then Yes.
R
ravimdxb
No chance mate since Tata Sky Thompson do not have a diseqc option and DD Direct+ is on INSAT 4B (93.5 E) and Tata Sky broadcasts from INSAT 4A (83.0 E). There is no option of also adding any transponders or channels manually on the receiver this is ofcourse done by use of controlled software by Tata Sky to protect content. Well also the encryption company is their own i.e. NDS or Videoguard !
Get an FTA Receiver to watch DD Direct+ or Dish TV is also another option since the satellite used by Dish TV is NSS 6 (95.0 E) very close to INSAT 4B and you get it on the same dish is you make proper alignment !
Good Luck!;);)
B
barathm
TATASKY
India
If i alignment the same dish to INSAT 4B can i able to get the DD DTH using TATASKY Receiver ?
In TATASKY Receiver their option add TPs by using this it possible for add DD DTH ?
athavale
Dish TV, Zenega STB
Bangalore, INDIA
No.
You just can't.
You will have to buy a new STB for that.
srei
srei
coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
north west india
IF SOMEONE IS ABLE TO FLASH THE RECEIVER SOFTWARE,it would be possible.
Skybox F3
And it would automatically upgrade itself again sooner or later
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
INDIA
Yes like Ag says, It will be upgrade instantly, when he points towards Nss6. Soo keep in mind.
