decided not to put my dish up
R
Rd100
decided not to put my new prodelin 1.8m up but to stick with a 1.2m or 90cm andrews,
CROSSBONES
CROSSBONES
S.Wales
Why the change of heart?
R
Rd100
As I will not gain much only nilesat weak horizontal transponders,
W
wod
yorkshire
stick with the 1.2m as going to 90cm will not get you the same as on the 1.2m dish surely
i'm wanting an andrews dish but cant decide between 90cm or 1m version
CROSSBONES
CROSSBONES
S.Wales
Yes, but it looks great having a HUGE dish in the garden:eek:
You never know whats around the corner;)
R
Rd100
Just brought a brand new andrews 1.2m this afternon to replace my old one:)
W
wod
yorkshire
rd100, why the need for a new andrews 1.2m ?
F
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
I would love to know how much Gain difference there is between same size dishes. My Triax 1.2 does me well but I always wonder.
R
Rd100
My original 1.2m is about 15 years old so i thought i would get a nice new white one as the other one had lots of moss etc on it
W
wod
yorkshire
andrews dish i guess would come out top as it has a matched feedhorn to illuminate all of the dish
rd100, any comment ?
F
frund
Wales. UK.
Most of what is available [sport films adult]can be had with a 1.2 quite a lot with 80cm. I would expect manufacturers to be up to speed but there is quite a lot of choice and maybe performance. My dish is in need of debirdmucking I may have a go this weekend. Would be nice if someone did a multi dish review.
CROSSBONES
CROSSBONES
S.Wales
I would go for a 1.2m Gregorian before an andrews. l know there hard to get, but there equivalent to a 1.4m dish gain wise. Also way lighter than the Andrews. my 1.8m Channel master on the mount, even i have trouble lifting it!! :)
W
wod
yorkshire
so fibreglass is heavier than a steel dish ? i didn't think it was i'm gonna be knackered in a few months then when i get an andrews to put up above my roof line
crossbones thought you benched 155kg which i bet is heavier than the 1.8 dish
The weights aren't 1.8m round though wod. ;)
CROSSBONES
CROSSBONES
S.Wales
I think the greg is made of ali, not sure.
Ye I do, I said I have a job lifting the dish, didn't say I couldn't;)
Thats also true rolfw bit wide to get my arms around lol
R
Rd100
They should not be a problem with the weight of the dish the az-el mount & polar mounts are make to take it as long as it is installed well there should not be a problem i have never known ant problems with CM/ANDREW dishes,
R
Rd100
You should get on the weights more oftern i can lift one with my one arm (only jokeing). Yer the 1.8m is a pain on your own due to the size of the dish you should try the 2.4m andrews smc you need 2 or 3 people then to put it on its pole ,
W
wod
yorkshire
take it i wont have any problem carrying a 1metre andrews up some ladders then only the bigger ones are heavy ?
