- Dec 10, 2004
- 1.2M Channel Master, 1224 motor, VU+ Duo 2
- North West
Hi rocklands,
there are 2 versions of Stealth 206, a & b,
Stelth 206b has a bug in it that stopped the AU feature working correctly, so if you have this version loaded I suggest you load Stealth 205.
Once the Stealth file is loaded you need to alter the settings in the Cam.
Enter the Cams menu, click on Configuration, and ensure the following are set:
Auto PMT (ON)
Emulators (ON)
Emulators Priority (1 Emu 2 Cards)
Once these are set ou should be able to open Premiere, D+, TV Cabo and TPS.
Auto PMT (ON)
Emulators (ON)
