Diablo Light Cam
catmar
Non-Activated User
Opentech ODS3000Ci Digital Satellite Receiver twin CI,
Diablo Light Cam,
80 cm Prime Focus Dish, HH140ALU Manhattan Motor, GTSAT GT-S40 LNB - NF 0.2db.
Malta
Well my new Satellite Receiver did not arrive today as I was told by the supplier that there is a problem with customs clearance..agggghhhh why me?
Okay while I'm waiting for probably another week or so can I ask another question to further enhance what I've learned on this great forum since I joined...the question is this, I have seen in the index of the manual for the ODS3000Ci a reference to upgrading the receiver via satellite, but I'm unable to find any instructions on how to do it should it be required.
I can say with certaintly that this receiver was not used for well over a year before I got it, so it may need an upgrade. If it can be done over the satellite great if not well I guess I'd better buy a nul modem cable so I can hook it up to my computer. Can anyone help me to better understand this process.
Thanks in advance
Mickha
North West
The Echostar receivers used to be capable of upgrading, their firmware, over a designated satellite channel on Hotbird. To do this you just needed to be on the satellite, Hotbird, and go into the menu and it would upgrade automatically.
Since Echostar stopped supporting their receivers, a few years ago, this service was halted.
If the service is available for your receiver it will tell you in the manual, if not it is just as easy to update the firmware using your computer and cable.
Shahid
Sony KLV26HG2 LCD TV, Humax HD-CI 2000 on a Fixed Sky/Astra/Hotbird.
Cerebro Card. Infinity USB Phonix. Dragon Cam v4.1 w/Firecrypt & Loader Card.
London UK
Dear Mickha
I am considering to get the Cas3+ and a Diablo Light Cam
Just to confirm that I can
a) Cas 3 can programe a Dragon Loader Card with the .dra file with only USB no serial connection needed?
:cool: Its easy as programming a Dragon Loader with just a single Steath File to the Diablo?
catmar
Non-Activated User
Diablo Light Cam,
Malta
Thanks Mickha,
That's more or less what I had worked out and don't think it's available as there is not a mention of it in the manual except for what is in the index, so looks like it was dropped a while back. There are firmware updates on their site so looks like I will have to buy a nul-modem cable, I need one anyhow.
Thanks a bunch, take care and more questions will be on the way no doubt.
Mickha
North West
Hi Shahid,
with the Cas 3+ you have 2 ways of upgrading your Dragon Cam, using only a USB cable.
1. You can program your loader card and load the cam as normal.
2. You can load new firmware using just the Cas 3 and the dummy card.
Programming the Diablo is different than the Dragon, but easy with the Cas programmer, as is loading new key bin files.
You wont be disappointed with the Diablo or Cas 3+.
Shahid
London UK
Mickha said:
Hi Shahid,
you mention ' loading new ky bin files' cant the new keys be added via remote control? as i currently do with dragon.?
Mickha
North West
Yes you can add the keys using your remote control, but at the moment quite a few of the good packages are AU, (Auto Updating) so there is no need to change the keys.
Before loading a new Stealth file it is advisable to format the cam, so then you load the latest keys.bin file, it only takes a few seconds, so is a lot quicker than entering them manually.
Shahid
London UK
so to round off my questioms on the diablo. 2 files are loaded on to the Diablo cam 1) The Stealth 2) keys Bin file?
Mickha
North West
All Stealth files include a keys.bin file, so all you are doing is updating it, the Stealth team haven't got time to produce the new software and update all the keys, so it is up to the user, and the easiest, quickest, method is just to update the new Stealth with the latest Stealth keys.bin file.
Shahid
London UK
Just ordered one from fleebay. Comes loaded with latest stealth.
Shahid
London UK
The Diablo arrived today with Stealth 2.08 fully loaded. All main 3 providers working!
Not bad for £60.00
tested now for an hour i can say i have jumped from provider to provider without the need of rebooting. clearance time when channel hopping to a new provider is 20secs or under. tests are on the Humax HDCI 2000
Yes, Diablo and the Humax are an excellent match.
I'd like to report that Diablo and the Fortec HD box behaved in the same exemplary manner, but initialisation can take several insertions of the cam before being recognised. A pity, as otherwise the Fortec is getting much more support for its software.
Shahid
London UK
Dear Llew
Now that I have the Diablo and no programmer to program it,how long do you think I will get away with AU of the 3providers before I will need to invest in a CAS 3 + ?
a) 1month
:cool: 3months
c) 6 months +
Mickha
North West
The Diablo team are fairly good with support so expect a new Stealth release within a month, but so far with D+, Premiere, TV Cabo, TPS and Polsat, all AU, and it being easy to manually update other keys, you should have a lot of viewing options, without a Cas 3.
But a Cas 3+ should be an essential item, on your shopping list, as the Diablo team have promised further major updates, and new providers, soon, according to the Stealth 208 read me file.
rocklands
fortec star HD
Oxford
Hi
I have tried to upgrade My diablo cam to 209 first I formatted the cam and then tried to load the stealth209.dup file but i am getting a an error "message run time error 429 activeX component cannot create object"
I am not sure what I am doing wrong
Mickha
North West
Are you using a Cas 3, and the latest 8.2 software?
rocklands
fortec star HD
Oxford
Thanks Mickha but I installed the software on another computer and it loads fine now
Shahid
London UK
so you updated you diablo with the stealth file .dup and the latest key.bin file?
tamagoch
Dreambox 500, Edision 2620 CXCI reciever, Cas 3+, Diablo light, MatrixCam reloaded
Finland
i just bought a new one and it came with stealth 1.58 in it.
I decide to format the cam before installing the current 2.10 and keys.
I am using cas 3. how then should i install the software now? please help!!
easkey
easkey
SpiderBox 9000 HD - Technomate 1500+CI
1M dish - 3 LNB'S
Astra 19 - Hotbird and 1W
Sky Box on 90cm dish
Diablo Cam + Cas 3+prog
IRELAND
tamagoch said:
I think this new stealth 2.10 can not on the Diablo Lite
only no the wireless version!!!!!
WHY....:confused:confused:confused
