Difference between G/T and EIRP?
O
Orthoclipse
Various
Just looking at the Arabsat footprints for 26 east. What's the difference between EIRP and G/T?
They seem similar for 3A but are quite different for 2D.
_http://www.arabsat.com/satgen/gen.asp?code=3kuband
_http://www.arabsat.com/satgen/gen.asp?code=2DKuband
ouagadougou
ouagadougou
2m NERA Prime Focus Dish for C/ku Bands, DM500, SkyStar2, Technomate 5500CIP, Force 1122.
Stockholm & Windhoek Namibia
G/T gives you the transponders effective Receiver Sensitivity and is comprised of a ratio between the Gain of the dish and the Noise Temperature of the receiver Low Noise Amplifier chain. Used by the stations linking to the satellite.
EIRP is the Effective Isotropic Radiated Power and is a measure of the total satellite transmit power including the Transmitter Output Power and the Gain of the dish minus any losses from waveguide etc quoted against a reference Isotropic antenna that has no gain in any given direction. Used by those of us who want to receive a satellite.
Hope this helps.
Cheers.
A small addition here, as ouagadougou says, the G/T is only really of interest if you are looking to transmit signals back to the satellite, as you would with 2 way internet by satellite. :)
Unfortunately and as with many other high tech things, when you do a google search for terms like these, the definitions/explanations of these are by technicians and are made up of more terms for which you have to do a google search, etc, etc. :D
ouagadougou
ouagadougou
Its a complete pain isnt it ;)
If you want to get really confused then try reading the Intelsat/Arabsat/Eutelsat/ITU documents etc etc. They dont just refer to addittional Technical Terms, they refer to complete addittional documents which also refer to other complete additional documents. Round and round in circles you go. All good stuff really though.
Cheers.
atoonra
Satellite
MidEast
Talking about G/T , means directly the uplink (i.e., the path from the transmit earth station to the satellite) .On the other hand EIRP related to the received signal strength from the satellite measured at the receive antenna(downlink) which is our interest .
Regards
