Digitalb - Can anyone help??
David Walsh
Digitalb Satellite Receiver Technomate TM-7552VA2CI
Fleet, Hampshire, UK
I have a technomate receiver TM-77552VA2CI which is set up to view Digitalb stations (CONAX Encription) and have a 6 month viewing card. Currently, I am receiving only free stations ie: My Music. When trying to view any of the encripted stations the message 'No Access' appears. Having spoken to the supplier, he has told me that the card is activated, but this was last Thursday (5th January) and I am still not receiving the channels.
Can anyone help or advise??
Many thanks in advance!
David.
If you go into the CI menu of the receiver, does it show the card listed?
PS Moved this from the Forum access and membership problems section.
David Walsh
Hi thanks for the quick response having gone into the common interface menu its coming up (with not installed?) any further help would be appreciated.
Rgards
David
Ah, is there another option for the embedded CAS?
David Walsh
Hi not that i can see there are two slots both saying not installed when you bring it up on the menu. However when you go to the heading smart card in the menu it says slot 1 conax (inserted) and beneath that slot 2 viaaccess (extracted)
Regards
David
OK, so it is seeing the card, what size dish are you using?
David Walsh
The dish is 90cm, but I think the dish is ok as I am receiving My Music which is a free channel. It won't de-code any of the encripted channels???
Cheers, David.
That's why I ask, the DigitalB channels seem to be weaker, have had loads of cases where people get perfect reception of Alsat and the other FTA channels, but can't clear the pay channels.
David Walsh
Just checked again the channels i am receiving.
Iwill jot down a few
My music (free)
Alsat(free)
Hot tv(free)
rtv(conax) but still works with card out)?
koho vizio (conax) works with card out)?
The signal strength bars on the channel my music are the same as on the channels i am not receiving?
Looking on some of the other forums there are two levels of digitalb cards one for some of the channels and a premium one which decodes the rest i wonder if i have the wrong one?
Can you shed any light on this.
Regards
David
