Diseqc 4in1 setup help!?
Likes
Hi folks,
I currently have the following setup:
1x Cherokee Worldsat Maestro Satellite box
1x 80cm dish with monoblock: Astra & Hotbird
1x Diseq 2 in 1 switch for the monoblock
1x Sky minidish
1x Sky decoder
I wanted to get rid of the sky box and cherokee and put in a dreambox (i have the dreambox but i'm playing with it still and getting used to it!). I have bought a 4in1 diseq switch and to be honest I just dont understand why it wont work correctly (im guessing its a receiver issue).
When I plug the satellites into the diseqc 4in1 I can get hotbird & astra but not the third lnb.
Once I tried plugging the dreambox in and it said it had problems fixing on hotbird when I was trying to set it up even though it was working on the cherokee...
I only have 3 lnbs connected, am I doing something wrong like an obvious mistake, or is it my box which isnt compatible?
Cheers,
Nt
Likes
1,286
#2
Sorry, but I am a little confused as to your setup.
You mention a monobloc LNB for Hotbird and Astra and a two way diseqc switch, then you mention a third satellite and a four way switch, how have you got this connected?
Likes
No... Sorry if i wasnt too clear...
I currently run a 2in1 for the monoblock and just a cable straight into the Sky Digibox for 28.2. The idea is to get rid of the 2in1 and connect the 3 lnbs into the 1 box...
Likes
1,286
#4
Still a little confused as to why you have a 2 in 1 switch with a monobloc LNB, as it has its own integral switch, or do you mean something other than monobloc?
Likes
Hi mate,
Old style mono-block (the originals in france were without switches). Any ideas as to the source of my problem?
Likes
1,286
#6
Ah thanks, you learn something every day. :)
With a four way DiseqC switch, you should simply have to set the LNBs as A, B and C (or 1, 2 and 3) in the receiver, which I'm assuming is what you are doing and connect the incoming LNBs to A, B and C. which version of DiseqC is the switch?
Likes
Hi again,
It says its a diseq 2.0... I'm thinking this could be what is causing the problems, I was unable to find any 1.2 diseq 4in1 switches!
Likes
1,286
#8
They should be backward compatible, but you may need to experiment a little, what DiseqC options do you have in the receiver?
Likes
1,286
#10
If you've decided that it is a compatibility issue, then try one of these.
