Diseqc motor or 36v actuator motor?
ALIEN1X
NONE YET
I was planning on using a 80-90cm dish with 3 lnb, but now would prefer to go motorised.
I was talking to a supplier from the link below
_http://www.satellitesuperstore.com/vbox.htm
I was advised that all DISEQC motors are not proper motorised systems and that a 36V V-Box motor with actuator is needed?
Other suppliers say it makes no diffence?
Is this true, what are the pros and cons and do I need one?
Regards
Alien1x
Well I'll give them one thing, they certainly stick to their guns, but unfortunately it's a little like King Canute trying to hold back the tide.
There is no doubt that a good quality actuator and V-Box is a lot more sturdy than a DiseqC motor, but it is also a lot more costly, you can buy a DiseqC motor for £40.
Eighty percent or more of our members who are motorised are using DiseqC motors with their systems and doing so quite happily with great results. If you are using a large or heavy dish, or have to mount your dish in an exposed location, then don't use a DiseqC motor, but for your average weight 80/90cm dish, a DiseqC motor will give you years of reliable use. :)
