Diseqc Motor Through LoftBox
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
Hey guys.. Currently I run a 3 lnb system using a diseqc switch. My feed from my switch goes through a loft box before it comes down to my dreambox 500-s. As it is , it works just fine. What I wanna ask is, I've just order MOTECK SG 2100A DIGIPOWER MOTOR DiSEqC 1.2 ,1.3\ USALS , considering my switch works fine via the loft box, do you think the motor will too ?
Should do, it is obviously accepting DiseqC commands and should be capable of two way traffic, it is after all only a diplexer/triplexer. :)
B16MCC
/var/tuxbox/config
Wow , rapid response, thanks rolfw. I guess its a suck it and see job, I'll post my findings after I've done the install.. Gotta get my guys at work to fab. me some nice pole brackets now.
Make sure that there is adequate adjustment to ensure a perfectly vertical mast. :)
