Diseqc motor
spoofer2005
Likes
Dreambox 7000s 60 gig segate hard drive
#1
My dish is all set up can only find a few sats thor astra and hot bird
im woundering if i have my motor upside down
would i pick up these 3 sats if this is true
i dont have a manual for the motor
plse help
Kind Regards
Likes
1,286
#2
Can you provide a picture? As a general rule, the "F" connectors are on the underside.
It could of course just be set up incorrectly.
gameboy
Ding Dang Doo
Likes
5
Scotland
#3
What motor is it?
Do you have a picture?
Chances are that it is the correct way up and it just needs adjusting more.
Likes
motorized,80 dish,thechnomate 1000 d universial lnb
#4
hi. i`m very new with satellites,and i just bought a dish 80 cm, a reciver technomate 1000 d and a gold motor h to h and a universal lbn, my question is , right now i can only find hipsat, can i catch any more, on just one lnb , right now i need all the help i can get , thanks alot.
my regards
spoofer2005
Likes
#5
Im a newbie myself
Yes 1 lnb is only needed with motorised system
From wht i have read and learnt first you must set the motor to 0 and then by turning the dish manually on the mount find thor 1w
then move the motor to find more sats fine tuning will result in receiving more than 1 sat
Likes
#6
hi thanks for replay, i should try that !!!!!!!
spoofer2005 said:
Im a newbie myself
spoofer2005
Likes
#7
Likes
1,286
#8
The manual for the motor is on the page you point to in your link. :)
Have you set the lattitude for your location on the motor body and what is your longitude?
jakenl
Likes
Manhattan Starlight 5900+PVR-80GB,Topfield TF5000CI,Skystar2,110cm dish, Invacom 0,3dB, Moteck SG2100A,range: 75East-61West,AMD Sempron 2600+, Windows XP Pro.
The Netherlands
#9
Hello Spoofer.
One question: Does your receiver support USALS? If so, the setup could be much easier.
In that case do the following:
In your antenna menu, fill in coördinates of your location; choose Thor with the USALS-command. The motor will turn to the right position. Then turn dish and motor together around the pole until best signal is received; tighten the nuts of the motorbracket.
Now your receiver should find any satellite via the USALS-commands.
Jakenl
spoofer2005
Likes
#10
Im sure it does its a Dreambox 7000s
i have tried this but with no luck
i have found many sites to caculate my long and lat
My location is Northampton England
my caculations are
4.217° W Long
51.033° N Lat
Correct me if i am wrong
Kind Regards
Thanx for all the suport from everyone Great forum
Likes
1,286
#11
jakenl
Likes
The Netherlands
#12
spoofer2005
Likes
#13
Likes
1,286
#14
Call it 0.8W that is about as close as you will get and very convenient for Thor. :).
spoofer2005
Likes
#15
sorry but i still dont understand
first what settings do i use for my dreambox it wont alow just 0.8
Also how do i caculate the settings for the motor
Kind Regards
Likes
1,286
#16
You should be able to enter 0.894 West , you certainly can on mine, then enter your lattitude underneath.
If your longitude coincides with the position of thor, you just set the motor at zero and by swinging the motor body on the mast and the dish elevation only, find Thor.
spoofer2005
Likes
#17
ok thats is what i have done
i receive only 3 sats astra hotbird and thor
wht position do i set the motor arm
as im sure im off the arc
KInd Regards
