Diseqc switch AND motor
rkhsaw
Humax, dragon, Matrix, 4 dishes
France
Does anyone know if it is possible to have both a diseqc switch and a positioner controled by the same receiver ? Ideally, switch inputs 1, 2 & 3 would be to fixed lnbs & 4 would pass the positioner info thro to the positioner.
Why ? Well the switch is so much faster for general use for the family but sometimes I want to scan the sky to see what I can pickup.
receiver, Humax CI 5100.
And a Happy New Year to everyone
closetosoton
More dishes than Sense.
Wavefield T55, 20 LNB's and a whole load of analogue boxes!
Close to Southampton
This is a subject close to my heart, since I have asked the question myself on more than one occasion - the short answers is:
- No one has really tried it and therefore can't really answer.
But that's not much use to you. I have personally looked into it a little further and come up with the conclusion:
- Possibly, depending on your receiver/kit.
I checked out the diseqc spec to see just exactly what it would support - and the following is my reasoning: Section 8.2 of the diseqc bus spec (http://tinyurl.com/44y67 from http://www.eutelsat.com/satellites/4_5_5.html ) seems to suggest different devices are addressed differently - i.e. you can talk to a switch and motor independently.
I have a 4-way diseqc switch the which has clearly hex addr 0x15 printed on it, I'm guessing a diseqc motor might respond to 0x31.
Say you put 3 fixed dishes (13E,19E,28.2E) on the switch 1,2,3 outputs and a motorised dish (say for 1W, 30W, 42E etc) on the 4th output:
In theory, if your receiver knew to send commands to the motor down through the '4th' lnb position it could work, however whether your receiver would support such a set up is questionable.
It would have to know to switch to the '4th' lnb position, then send the motor command and know it was looking for another sat (1W, 30W or 42E).
Someone with a sat-PC card commented that he could send diseqc commands in a chosen sequence, thus in theory that would work - with the proviso that the switch didn't filter out the commands and pass them on to the motor.
I haven't a cheap diseqc motor to test out my theories - which comes back to the first answer - no one really knows.
Of course the next logical step is to try it. I know in my receiver (Samsumg DSR9500) it is possible to configure both a diseqc switch setting and a positioner (i.e. motor) for a given satellite - your receiver should have this option as a minimum before you try anything.
Well I hope that's entertained you even if it hasn't given you the magic answer you were looking for. What ever you do - please report back, many of us are interested to see what happens exactly!
Cheers
CTS
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Well written answer!
I think it was probably me that mentioned the PCI card software to feed raw diseqc. I'm going to get a switch, but just haven't got round to it yet what with lots of other things going on.
I'm hoping that the plugin in question will work, once I know what commands to use for switching.
Here's a pic. You can edit the RAW DiSEqC command to whatever you want and seemingly send it.
rkhsaw
France
Many thanks, guys, for the replies. It's about as I thought, technically possible but may need some "customizing" in practice. I'll try some tests and keep you informed.
- A possible "workaround" is to use a 12v lnb switch (I have a spare one) to switch between the diseqc switch & positioner. The receiver has a 12v switch output but I guess the firmware would have to be patched to make it useable.
rkhsaw
