den123 said:
ok thanks so i turn all the dish with the pole untill i fine 5deg west what satelite is that mate thanks den do i have to put the settings in the reciver the satelite 5deg west thanks
Checking your previous posts, I understand you have the Humax HDCI2000 - put this in your profile!
For Humax HD (not the easiest STB to use when setting up a dish from scratch) -
Menu
Down to bottom pic (Search Channels)
Select Antenna - OK
Down to Edit Antenna
Click OK ( List)
Select Atlantic Bird 3
Save
Click on Transponder
Select a TP (11.590V is easiest, or go to User Define and enter a frequency etc. on that satellite that you can receive (from Lyngsat)
Here's where signal evaluation falls down on the Humax, as you are likely to see no signal on the signal strength bar, unless it's changed since the last software update.
Go down to Search and hope that your dish is aligned correctly on that sat.
N.B. The above assumes that you have set up your coordinates in the Motor Antenna menu.
