DISH TV reception-- urgent help
jc001
2m satellite dish
hk
I am new in setting up the dish. I have a 90cm KU band facing the NSS6. and I have a Zenega CD1004is. it said no signal when I connect the Zenega stb to the dish, but when I used other satellite stb, it said 60% reception strong. please help asap. do I need to set something in the Zenega STB?
afancier
Zenaga STB CD1002S, Three solid Ku band Dish. 60Cm,70cm,90cm getting Nss6 95E, Yamal201 90E, ABS1 75E, EuroBird2 26E at 26E. Disec SWITCH
Amritsar
are u tryingDISHTV TP in both STB............... what is ur location........... are u in HK.....................
jc001
2m satellite dish
hk
I am not in HK. I am in tibet, can receive NSS6 for indian DISH TV signal clearly. yes I am trying DISH TV in both stb.
afancier
Amritsar
sorry.......... today i quit this Forum.................... as they don't have respect of working people...................
RealInfo
DM 120 cm dish
Punjab
try with 150 cm dish
varunous
nss 6, windows xp
dubai
hi I ve got a zenega 1004 is ( i know its a bad start.....) my buildng has a centralized dish system working on diseq and 22khz. my lnb setting is on diseq 1.
When i conect the cable directly I get two transponders
12638 v 13300 (45%/60%)
12688 v 27500 (29/35)
when i do th splitter trick i gain one transponder but i lost one as well ( strange)
12638 v 13300 (40/50)
12534 v 40700 (47/55)
but i loose 12688 v 27500 (2/3)
when i tried to attach an in line amplifier 10db (950-2150 mhz) I got no signal at all
Does any body know if this is due to disceq system istalled or something else
is there ant other way i can amplify the signal
when i use the same line with a diffrent reciever (starsat) i get more than 60% signal for 5 dish tv transponders
guys please help
