DISH TV - ZENEGA CD 1004 iS SATELLITE RECEIVER SOFTWARE
M
muddu
KU-band DTH , Dish TV INDIA
china
hi sir
i have heard of some website who telecast online Tv of Indian channel , & they give som modem type unit which we have to connect it Internet Lan then to Tv by this we can watch Indian channel anywhere in world , is that true ? if it is plz let us know how it work so that we enjoy indian channel here , thanks u
muddu/...
D
dspdsp
DishTV DTH
Zenega 1004s Receiver
90cm offset Sharp dish antenna
india
You can watch it online h**p://www.tvunetworks.com.You will need to download the player.
D
dspdsp
DishTV DTH
india
ashhish
satellite box
j&k
i have zeenega cd 1006s model set top box it hangs on updating set top box software do not swich on
N
newcomer
sky
nottingham, UK
HI guys,
I am from Nottingham, UK. I have recently bought the dishtv receiver. Does anybody know whether or not I can receive the channels? Will the basic sat dish be enough that is used by sky tv or do I need to buy a bigger sat dish as this - Fortecstar 185cm Satellite Dish from Maplin?
Also assuming I need to buy the the mentioned sat dish do I need to change the frequency too?
your help would be much appreciated?
Thanks in advance
C
cheap_deal
Eurostar 180cm single panel dish,
prime focus lnb
UAE
need some help setting up dish tv at my dubai residence.
most importantly if i bring the smart card, what kind of receiver/stb can i buy locally in dubai? the lnb, dish cables i can get from dubai itself right?
K
kaySun
Zenega CD-1004iS
Humax IR-FREE
Alfa AD-7300+
Philips XD-300 (Modified for a particular NW)
Chennai, India & Middle East
Nope you can't do that...if you can outsmart the link of the STB serial number to the card somehow on any other box that you buy in Dubai YES you can do it. In case you happen to do the R & D and is successful please do not forget to post it here as so many of us do not like CD1004is. That reminds me of UEC whatever that used to be dished out by Pehla in ME...just hanging eternally on lost signal for ever like "until death do us part". Good luck.
B
blacklist
DishTV(Indian),NileSat,Asianet,Computer Network
Kuwait
member91040 said:
Pra bro...! Its easy try to find our old post regarding 232...! You will find whats first and then next ok bro....!
Hello Sir
I am new to this site. With all due respect sir where do I connect the RS232 cable in Dish TV Zenega CD1004iS box? Because there is no Serial port in it or do I need any differ kind of connector to connect it. Please Advise.
Warm Regards
Sorry for double posting
R
rajendra555
zenega4is
qatar
hello everyone
i am in qatar
i am getting 186 channels with zenega 1004 is receiver with full strength
by using 6db attenuator and splitter
attenuator + splitter is boosting signal too much
without using attenuator + splitter only 50 channels only coming
try it
get good dish adjuster & i am sure you will get more channels
L
lut2u
AIRTEL AND TATA SKY
QATAR
Hello Rajendra555,
Im in Qatar too and need your help.
Yesterday I switched from Sun Direct to Dish TV and I have no reception.
On the net my account status shows as Active.
Thx
Kind regards.
R
rajendra555
zenega4is
qatar
You have to buy attenuator and splitter from radio shack - electronic shop located at city center
lut2u said:
Hello Rajendra555,
Thx
Kind regards.
L
lut2u
AIRTEL AND TATA SKY
QATAR
Thanks.
I shall do that.
Any particular way to fix the 6db attenuator and splitter.
just mail me at Email Removed - Admin
Do you have any tel. number of Satellite Technician who can tune the dish most effectively?
R
rajendra555
zenega4is
qatar
Your path should be "dish----dish lnb ----cable-----6db attenuator------splitter---dish tv receiver"
6db attenuator is like cable size it will fix in path of your cable.(it is very small instrument) just buy it, you can easily fix.
S
Saaju
Zenega CD1004is
Dubai
Dear Freinds,
Iam Using zenega CD1004is Receiver for Dishtv,
when I powered up the system it was showing one message indicating
software upgradation.After completing 100% upgradation system setup box
restarted automatically.After that one error message started,ie
*303.NOT INSTALLED.*
*"No Services installed,please install your set-top box by pressing OK
button"*
After pressing OK button,channel search started and Error message getting,ie
*"Installation failed.Verify if your set-top box is properly connected to
the dish.Then press ok retry"*
Checked and Confirmed dish cables are properly connected and intact.tried to
restart with Vc card and from Power switch But Unfortunately same ended
without any success.
It seems some problem with software/firmware.
Any body pls help me to rectify this issue.
F
fahad101
dish tv
bahrain
asdf68 said:
By moving the both ends of the coil up and down (towards input side or outputside)i can adjust the signals.
which ends you are talking about, today i tried by soldering both ends to inputs as Mr odiyan showed, but i could not find any difference in signal. please help me solve this problem.
J
jeevankumar
NSS6
patiala
i have zanega 1004is new model . in new zanega model there is no serial port jack available how i download software set to set
J
jamsorbit
I Want dth indian channel in behrin pls help me
asdf68 said:
Dear Mr.Surendar,
can you please explain the procedure like how many coils we have to use and where to connect the wires.
G
Gangadha
zenega stb to stb softwere downloading system
bargarh
Dear All.......
I want Zenega CD1004is OLD SOFTWARE downloading procedure.
If anybody have idea pls reply......
Ganga
K
kaySun
Zenega CD-1004iS
Humax IR-FREE
Alfa AD-7300+
It would be nice if rajendra555 could post images of 6db attenuator and the type of splitter that has been used. I wonder how he got high gain out of splitter and if video pixalation occurs as a result of high gain as noise spots.
R
RANSON
DishTV
UAE
Great job. This works fine. Except some other frequecy of horizontal channel are not tuning. Any idea to get this back.
