dodgy cable connection on DB500
K
kebabinho
Likes
dreambox 500S
80cm dish
.2db lnb
Gemini 3.5
CCcam1.71
Sky netgear wireless router
zoom gameport ethernet adapter
satankeybundle + autoupdater
I think my box has a fault and need some advice. i have a static sky dish with quad lnb and a 80cm dish for foriegn channels. if i connect the cable i use for my foriegn channels into the quad lnb on my sky dish, and connect this to my sky reciever it works fine. if i then try and connect it to my DB500 i cannot get a lock. i cannot get a lock from my foreign dish either. the thing is i cant seem to get a good connection between the cable and the IN connector on my DB500. i have to strip the cable of the connector and then push that in the IN connector on my DB500 to get the values to move and even then i still cant get a lock.
when i look at the back of my DB, the OUT connector has t plates inside it the pinch the cable once inserted making a storng connection., the IN one does not however. is it meant to have? is there anywhere i can get this fixed?
-kebabinho
BGonaSTICK
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#2
Why don't you try tinning the signal 'core' to make it a better fit?
_http://www.mediacollege.com/misc/solder/tinning.html
K
kebabinho
Likes
dreambox 500S
80cm dish
.2db lnb
Gemini 3.5
CCcam1.71
hi,
im not the best at soldering and would probably make it worse? is there anywhere i could send my box for repair? im annoyed cause i have only just bought it off ebay and it looks like i was broken before i bought it. i might have to try and claim my money back but im not hopeful.
kebabihno
BGonaSTICK
BGonaSTICK
Likes
Brighton
#4
Tinning is virtually impossible to screw up if you use a good quality solder with flux and if you do make a mess, just cut off an inch of cable and try again :)
Not an ideal solution, but if you're not going to be connecting and disconnecting it every five minutes it might save you a lot of grief.
Likes
1,299
#5
Send it back to the seller, the connector needs the core clamp to function properly. Is this a new unit?
K
kebabinho
Likes
dreambox 500S
80cm dish
.2db lnb
Gemini 3.5
CCcam1.71
the sellar says it was new. The thing is he says he bought it by mistake as he was after the cable version. looks to me like he was trying to ram in the cable and has broken it.
Likes
1,299
#7
Certainly sounds that way, can you take picture of the part, it may be a relatively simple repair.
K
kebabinho
Likes
dreambox 500S
80cm dish
.2db lnb
Gemini 3.5
CCcam1.71
possibly. all it is the the rear connector where you plug in the cable from the dish. if you look through the tiny hole there are two bits, one down each side that "pinch" the cable to get a good connection. i think all recievers have this
Likes
1,299
#9
I was wondering if you'd had the top off and could take a picture, all connectors have the gripper in the middle, bu it is whether this (the connector) is an integral part of the tuner or not. If it is, I would send it back.
K
kebabinho
Likes
dreambox 500S
80cm dish
.2db lnb
Gemini 3.5
CCcam1.71
i dont want to take the back off and break the warranty seal unless i have to. The connector is where i plug the cable from the dish into so i think it is quite important. i have sent an email to the seller and if he doesnbt repky ill try ringing him. he only kives 15 minutes away
-kebabiho
BGonaSTICK
BGonaSTICK
Likes
Brighton
#11
kebabinho said:
... he only kives 15 minutes away
-kebabiho
Well, it's a no-brainer then. If you're sure it's the box at fault, go knock on his door, and take the largest m8 you have with you!
Likes
1,299
#12
The way you were talking initially, it sounded like you'd looked inside, so if you haven't, as STICK says, taking it back is the only option.
K
kebabinho
Likes
dreambox 500S
80cm dish
.2db lnb
Gemini 3.5
CCcam1.71
its gone to an ebay dispute.
quick question - i have oticed on other adverts etc that you get a european to british plug convertor in the box with the dreambox. is this right?
- kebabinho
BGonaSTICK
BGonaSTICK
Likes
Brighton
#14
Don't know - mine came from Germany like many here...
B16MCC
B16MCC
Dreambox Gimp & Coder
Likes
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
#15
I got a converter in the box with mine from a supplier local to me in the UK.
