Hi genius5000,
I've just re-checked the keys for SRG and they are correct on:
_http://www.sat-key.org/
full keys on:
_http://www.turkeyforum.com/satforum/showthread.php?t=2915
You could try loading Predator 3.10 and then inputting the keys manually, even if they appear to be correct, and see if they open.
_http://www.ucassupport.nl/dragonsupport/english/Software.htm
When the card is loaded follow these instructions exactly, failure to do so could result in you damaging your Cam.
If your Cam is not in the receiver. Make sure your receiver is tuned to a FTA channel, switch off your receiver. Insert the programmed card into the Dragon module. Insert this into your receiver and turn on the receiver.
If your Dragon Cam is already in your receiver, tune to a FTA channel, I always use BBC World.
Turn off your receiver.
Insert the card, chip face up.
Turn on your receiver.
Go to the Common interface menu on the receiver, and select the "Dragon Loader" module.
In the next menu, select "yes, Load module".
Now a menu appears indicating that loading is in progress. To see the actual porgress percentage, select "refresh". There is no auto-refresh because some receivers had problems with that....
When loading is complete, a menu appears saying "Loading successful". REMOVE the loader card from the module.
Now turn on your receiver and your Dragon Cam should be updated.
Best wishes
Mickha
