dreambox 500s wireless?
dasteelman
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
anyone know the best way to connect my 500s to wireless router#?
S
Sharkadder
Dreambox 8000 HD PVR+DVD, 80cm Dish, 1.2 Compatible Motor, Quad LNB, Samsung 22" 1080p HD TV/monitor, Yamaha RX-V765 Amplifier, Tannoy Mercury FC Centre Speaker, 2 x Tannoy F1 Custom Speakers, 2 x Tannoy FR Custom Speakers, EPOS ELS Sub Woofer
Teesside (North East England)
im also after knowing this, my router is downstairs and my laptop and dreambox is upstairs in my bedroom.
I hear the best thing to do is cable it but i obviously cant so what ill have to somehow do is connect the dreambox into my eithernet port on my laptop and then transfer files/connect to the internet that way through my wireless network card.
the downside of course is if the connection cuts out at anytime while sending data to the dreambox i hear its a hard job putting everything right again if you use wireless.
Quite how you actually do set it up like i want and how i persume you want im not sure, hopefully somebody can explain hehe
mhku
mhku
TM Nano ~ sg2100
Midlands
Try a search on "Etherrnet bridge"
I can't remember if it works with a DM500 but there are some posts that will help.
dig deep
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Yes it will work, but still not a good idea
You can´t make this connection secure :)
gandalfthegrey
gandalfthegrey
Dreambox 800HD (clone)
Gibertini 85cm dish
4 way Diseqc switch........
linksys access point connected to Dreambox..
dublin,ireland
Hi dasteelman..
I use a Lynksys G wireless access point..my wireless router is in the front of the house and my dreambox and access point are at the rear...the access point is sitting under the dreambox it picks up the signal and transfers it thru a cat5 cable where I can update images/keys etc..It can be a bit finiky to set up but I got all the help I needed here in the idiots guide..plus a lot of help from super mod john graydon who just happens to be local to me so I could contact him personally. hope this helps..good luck
gandalf
S
Sharkadder
so to connect you the router you have to go from dreambox to router, you cannot go via computer (only to update files).
so if i want to do 1 of these services where i have to be connected to internet all the time i will have to cable it from box to access point, i cannot connect to my laptop and go through its wireless connection.
ok i think i get it.
I buy a wireless access point and connect my dreambox to that in my bedroom or something, instead of taking my dreambox to the router
S
Storm55
Mondeal 7500 + Dragon cam. 1M moveable dish
DB500s
Torbay, Devon
I have a wireless wanadoo connection in my house. My laptop is wireless but the 500s is hardwired to router. I just put the ip address of the 500 into my laptop, and can load images key bundles etc. Only problem is new laptops do not have aserial port to use dream up.
Tim.
sonic1
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
I use a bridge on my TM9100 and used it on my DB a few years back with no problem, I used the guide in the sticky's here and even bought the bridge described in the guide.
Without questioning Dig as I have know he is very knowledgeable but the bridge uses the same 128bit security as my router so I assume this is as secure as my router.
B
blueboyrio
Technomate 5200USB Echolink, 80cm dish and a motor
Blue Planet
I put my old pc connected via the cross cable to the dreambox and the pc is using a usb wireless connection to the route. I have shared the internet connection on the pc and put the ip address on the dreambox like 192.168.0.4 and is working fine.
Leee
Leee
Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
47°N/8°E/490m
Wireless ethernet bridges will support encryption - let's not say they're "not secure" - you just have to set it up correctly.
You need a good connection should you want to record or stream effectively across this wireless connection - G or pre-N/Mimo will help (as well as few walls, etc).
dig deep
dig deep
Prince of Birthdays
Sweden
Sorry about the security guys, I am somewhat overdoing this :)
Let us say that 128 bits is good then (for heavens sake) change the password to the box:eek:
U can´t be too secure today
L
laserquest
Dreambox 500s,Gibertini motorised dish,Titanium 0.2db LNB
Birmingham UK
I've just ordered a Belkin wireless gaming adapter (Bridge). It hooks into the ethernet port, and is the same piece of kit you'd use for a slingbox.
Costs £39 delivered.
Will let you know how I get on.
(Also have a Dreambox 500s on the way)
S
Sharkadder
you best let us know how you get on.......because i have just ordered the same thing lol.
waiting for it to arrive in the post now that i have some cash to spend this time of year.
I hear these can sometimes only work with certain ISP's. I've also orfdered one of these wireless digisenders so i can transmit into another room, i'm not sure if i can have 2 scart connections into it with it being a digital one but i'll see when it arrives in next few days.
but i will also let people know how i get on. :)
W
wedgy2k
DM500s, 80cm Dish, 6degree MonoBlock 13e/19.2e. Pli Jade Max Var
Portsmouth
Has anyone tried these with their DreamBox?
_h**p://www.cyberselect.co.uk/product/1275
Ethernet over the mains.
My kit is on order and this is how mine will conect to my netgear. (I'm desperate for it to arrive)
1st post, so hello :)
L
laserquest
Birmingham UK
Well, the Belkin gaming adapter seems to be working ok. Once in it's virtually invisible (other than to the router and DM of course) and you can't log into it directly. It seems pretty secure to me.
C
czp
DreamBox 500s
China
Motorola WE800G can help. I am using it.
S
Sharkadder
i also use belkin gaming adapter and you can log into it directly, belkin have a web interface port, i forget what it is but you can change numerous things on the bridge such as ip address and add a WEP key if needed for it to work.
works a treat but theres meant to be some 64kbit ones available which work better than the belkins.
V
vlb_pds
DM 500
uk
Hi, I would like to connect my dreambox 500s to pc and need some help. I have wireless system (D-Link, Air plus G2.4GHz wireless access point with D-Link USB stick). Many thanks.
Vlb
S
Sharkadder
sorry.....ethernet only dude, i have the same model, no usb interface.
what you need is to buy a wireless ethernet bridge or wireless gaming adapter or something with ethernet interface.
USB stick is no good, you connect box to pc via CAT 5e/6 LAN ethernet cable but even so your better off connecting the box directly to your router/modem using ethernet cable
W
wedgy2k
Portsmouth
I would like to point out these work OK for keys and connectivety
They are not fast enough for VLC front end:mad:
By running a long ethernet cable across the floor VLC FE worked fine
But would not work through powerline adapters
Apparently there are some 200mb models available
Or I could re-wire my house.....
