dreambox and sky cards?
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
i agree with what john_graydon said above.....when this is perfected, and working ok, i think a how to guide should be typed up by someone.
although its very interesting to so many, its not very straight forward either, not if your a newbie or not used to doing things manually anyway
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
I'm just setting mine up at the moment, but can't get either gbox or NewcamD to work any which way ATM.
Think I know what the problems are though. Firstly, I'm using the BOXID from my current $ky box (with my FTV card) instead of the BOXID of the digibox to which the card was originally matched.
When I blow the dust off my old box and get it running again, and I extact the info I need, it should work. Also got gbox installed on Gemini 105, but no emulist.xml to mod so I can't switch to it! Will install it on Hydra Zeus soon aswell, as I know how to mod the smartcam.config file to fire the blessed thing up!
When I've got it all sorted, I'll write a quality how-to for real idiots like myself...
:D
RedDevil_UK
Retired Mod
Rochdale
Put me at the top of that list :)
Tiggy
:D
Stick me on the list BG, will try on thge 7020
Regards,
Tiggy
Russell Too
trident;Provision V; GBSat
DreamBox 7000: 1.2mtr Wok
USALS:Ethernet;Router (ZOOM);PC.Two Screens.
OH, and a TV.
HI RedDevil_UK
Not heard from Sly in seven years regarding monies owing?
Their claim could be time barred, Suggest, Google, or ask for free 30 mins advise from solicitor etc.
Regards Russell
RedDevil_UK
Retired Mod
Rochdale
hi russell,
ive paid it now, the letter came from a collection company on behalf of sky, threatening all sorts in 5 days from the date of the letter if i didnt pay :(
including CCJ, court, bailifs etc etc. it was a nasty letter actually.
i didnt actually ring the collection company, i rang sky directly asking what i owed them money for?? after i paid using a debit card over the phone..... 15 mins later the collection company rang confirming that they knew i had settled the debt, and i would receive a letter of such soon after in the post.
and i did. 3 days later
bmcanulla
Hi
Could anybody help? Just installed all nessery gbox software (also edited files and created nos file) and infinity card reader on rs232. Inserted sly card and nothing happened. Do i need to install software or change somthing to get
the cardreader to work?
Regards
Bar
Nick -D-vB
Just found this on OzSat:
Equipment needed :-
Dreambox 7000, 7020. Multiboot enabled
Pheonix compatible reader (serial version).
12v power adaptor for pheonix reader.
Hard Disk or USB stick.
Gbox emu 1.35 (Can be found on most upload centers/ Note the files must have the GBoxKeyGen)
S*y Uk/Italia NDS Card
S*y UK/Italia receiver
Decimal to Hex convertor (Windows Calculator)
1) Obtaining the Hexadecimal values of your S*y card and receiver
S*y Card
If you look on the back of your S*y UK/Italia card you will see a 9 digit number across the middle.
e.g 123 456 789
Take away the last number of this 9 digit number so you are left with an 8 digit number.
e.g 123456789 becomes 12345678
Open up Windows Calculator or your Convertor. In Calculator click View Scientific. Make sure that Decimal "Dec" is selected. Type in your 8 digit number into Calculator and now click on "Hex". This will give you a 6 or 7 digit Hex number. You need to make this 8 digits long. To do this you need to put in 0's at the start of the number. So if it is 6 digits long then put in two 0's at the start of the number. If its 7 digits long then put in one 0.
e.g. 12345678 becomes BC614E (6 digits) so becomes 00BC614E.
This is your hexadecimal Card Serial. Write this down.
BoxID
To obtain your BoxID you need to go into your receiver information. On a S*y UK box this can be done by using the Services button, System Setup menu, option 5, 'System Details'.
Your Receiver serial number will be a 10 digit number. You need to make this an 8 digit number by taking the two 0's off the start of the number.
e.g. 0012345678 becomes 12345678.
Now you need to convert this number to Hex by using the same procedure as stated for your Card serial. You also need to make the number 8 digits long by inserting 0's at the start of the Hex number like the Card Serial. Write this second number down. You will need to write down which number is which.
2) Creating your NDS file for GBox
If you have downloaded the correct GBox files you will have a GBoxKeyGen.
To get the KeyGen working you need to run reg.bat which will register SecureCrypt.ocx in your system registry. You now need to open GBoxKeyGen and type in your Card Serial and BoxID that you obtained in Part 1.
When you have typed in both numbers click the "Click to create NDS file" button. This will give you the information you need in the text box below your serials. You need to copy this to your computers clipboard. Select all the text. Right mouse button and copy.
Open up Notepad or any text editor. Paste the text into notepad. All the text should remain on the first line in your text editor. If not then delete any carraige returns.
Save the file as
NDS
with no extension. If your using notepad then click on *.txt and change it to *.* before typing in NDS in the filename box. If the file has the .txt extension then it will not work.
You now have all the files.
3) Making sure the image will work with Gbox.
If you have a 108 or lower image installed then it is advisable to upgrade to a 109 image. I have found that I could not get Gbox to work when running the image from the flash. This does not mean that the emulator will not work when the image is in the flash it means I couldn't get it to work. I will explain how to get the emu to work on an image installed on a hard disk.
You need to make sure you have Multiboot enabled on your dreambox with an image installed on the hard disk before continuing with the rest of this guide.
4) FTP the files across to your dreambox
Using your selected FTP client you need to copy the following files accross to your dreambox to the following locations.
Make sure you put the files in the HDD/fwpro/[image name]/var and not just /VAR
NDS --> HDD/fwpro/[image name]/var/keys
softcam.cfg --> HDD/fwpro/[image name]/var/keys
gbox_cfg --> HDD/fwpro/[image name]/var/keys
gbox --> HDD/fwpro/[image name]/var/bin
5) Check the emulator is working.
Make sure your pheonix reader is set to Pheonix mode and is working at the 3.57 or 3.58 frequency. They are jumpers on mine that are used to change it. They may be different on yours I do not know as I don't have what you have.
Now connect the pheonix reader to the back of your dreambox via the serial port, plug the power lead in and insert your S*y card into the phoenix reader.
Before adding the emulator to your emu list you can check it is working. To do this you are going to have to telnet your dreambox. So reboot your dreambox and boot to the image you have just installed the GBox emu to. Select Common Interface in your emulator list. This is done to make sure no emulator is using the card slots. Now press Menu --> Expert Setup. Make sure that "Do not open serial port" is NOT selected. Now reboot your dreambox.
Telnet your dreambox
I use windows telnet but you can use others.
Click Start --> Run
type in telnet then press return.
telnet will open.
Now type in
o IP.of.dreambox change this to the IP of your dreambox
You should be taken to the login page. If not then check that the IP is correct.
Login is usually - root
and pass usually is - dreambox
If they aren't this then you must know what they are because you have changed em.
You will then be taken to the command prompt.
Type in
cd /var/bin [return]
then
chmod 755 gbox
then
./gbox
this will run the emulator and you can see all the information on the screen in front of you. What you are looking for is after Card Init 3. If nothing is displayed and you get entering main loop then your pheonix reader is either not connected properly or not set correctly.
If you have done everything correctly then your card will be recognised and identified.
If you get an error like this
This file is for NDS card 223XXXXXXXXX then you have not written the NDS file correctly. Go up to step 1 and try again.
If you don't get any errors and all is ok then you can now edit the emulator list.
To stop GBox press
Ctrl + C
It might take 15 seconds to stop.
4) Editing the emulator list.
I am going to show you how to edit the Hydra Pheonix emu list. There are guides dotted around the internet for other images this is just a rough guide.
Download a copy of your smartcam.config file from your dreambox. Do this via FTP.
The file is located in
/hdd/fwpro/[image name]/var/tuxbox/config
Now open this file in note pad and insert the following
osd-name X= GBOX
emulator X= Gbox [v.1.37]
camd X=
daemon X= gbox
kill X= gb
sleep X= 4
zap-sleep X= 4
change X for the number you want Gbox to appear in the list. Be careful not to allocate a number already used.
Save the file and upload it to the location you got it from.
Now reboot your dreambox. Turn to a S*y channel. ITV usually is a good one to test on. Press the blue button and select Gbox then start the emu.
I hope it helps someone,
Any news on a plain linux or window$ port???
Nick.
dago
search the net; newcam 528 nds. with the right files, you can do away
with the sky box.
regards.
BGonaSTICK
Brighton
Well, I've got GBOX running nicely on Hydra Zeus, but can't get the NewcamD patch to work at all on any image. I'm going to try again tomorrow with the same NewcamD files but from a different source. Gotta be a stupid error somewhere, or a bad file.
If it can be done, I'll make sure everybody here who wants it can get it.
I tried to explain the significance of what I was doing to my good lady wife, but she just said that she could get ITV 'FTA' on analogue terrestrial, so why was I bothering? :rolleyes:
Recorded Jamie's School Dinners onto my Dreambox HDD though, and that made me feel a whole lot better. :D
RedDevil_UK
Retired Mod
Rochdale
to be honest, thats the only reason i want to beable to do this.... so i can record Sky programs onto my DB hard drive
with the dreambox, i record loads of programs during the day, and watch them when ive more time at night..... and when the misses has finished watching all the crap soaps!!!
racingclubuk
www.racingclubfc.com
IBM Supercomputer
Ogmore by Sea - South Wales
also interested in getting newcamd to work - have tried & failed........
tried the DaVinci image with the newcamd NDS & followed instructions from toes about adding boxid but no joy. seems not many other have either :(
chuckles
The davinci image is a good route to take as the cardserv.cfg there works fine. Just add a line as follows:
BOXID = 0000000000
File is in /var/tuxbox/config/
Replace the 0's with you digibox seriel no.
You also need to replace cardserver file in /var/bin with the file carderver0961 and rename it to cardeserver
Depending on the image you are using the cardserver file should be renamed the same ie
Gemeni - cardserve
Hydra - carderver.dream
That all there is to it!
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
I recorded Jamie too, on my HDD.
The one in my DVD recorder or was it the one in the video. Anyway one button jobbie.:D
racingclubuk
IBM Supercomputer
yeah - thought I was prob missing the 'proper' cardserver.......
can't find cardserver0961 anywhere tho......?
Any ideas?
chuckles
Any ideas?
Are we allowed to posr links here?
If not then pm me with your e-mail and I will forward link or file.
RedDevil_UK
Retired Mod
Rochdale
we can post links, but dont post the file :)
Nick -D-vB
I've know people have got this working on the SkyStar1 DVB-S card with VDR,
If anyone out there has got a DVB-S card and a dreambox have they tried it windows with a NCD client plug-in?
racingclubuk
IBM Supercomputer
waheyy - got it working with newcamd under Gemini..
cardserver0961 was the way to go :)
do a google search for 'newcamd 525 nds' - its a fun file (hint hint)
watching E4 as we speak :)
cheers to chuckles as well
