Dreambox internet connection problem! Help please!!
kolaz1
Hello guys!! I would like to ask you what settings should i put to my pc and dreambox in order to be connected to internet, because i have some problem with that. I have a lan with dreambox and doing ftp but can not connect the dreambox with internet. When i telnet to dreambox and ping www.ibm.com the answer is "Host name failed"
I have a dial up connection with modem(no router), windows 2000 and i have put
pc
IP address: 100.100.100.2
Subnet mask: 255.255.255.0
Default getway: -
Preffered DNS server: The DNS server of my ISP
Alternate DNS server: The altern. DNS server of my ISP
dreambox
IP: 100.100.100.1
Netmask: 255.255.255.0
Nameserver 100.100.100.2 (used DNS server of isp but nothing again)
Gateway 100.100.100.2
Enable network, port 80
I appreciate your help ......
Thanks in advance
CHRIS
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
you with AOL..? if not...ignore this msge
Do you have internet connection sharing enabled?
PS. An unusual choice of IP range for the private network, the normal selection would be more like 192.168.0.1 for the PC and 192.168.0.24 for the Dreambox, you can of course use anything you want, but it is probably better to use a range designated for LANs.
The 192.168.xx routes packet requests onto an internal network. 100.100.100.x etc is an allocated domain out on the internet! (It doesnt seem to route anywhere as if you put http://100.100.100.1 in to your browser, it doesnt resolve). (There is a second internal domain ip address range = 127.0.0.x) And make sure you keep the subnet masks the same.
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Yes, Analogue is right.
Set your PC address to 192.168.0.1. Set your Dreambox address to 192.168.0.24. Set the gateway addresses AND the DNS addresses on both to 192.168.0.1. Set both subnets to 255.255.255.0. Turn off DHCP on both machines, and set the PC to run ICS (Internet Connection Sharing). Do ths in the properties of your PC's external network connection (Internet connection), or use the network setup wizard.
Good luck.
STICK
kolaz1
Thanks guys, i solved the problem, you were right it was internet sharing settings that created the problem...Now everything works fine!! I saw that Mary is not in Hydra menu anymore...The other 3 keys choices are fine? How can i put manually keys to dreambox (with what surfix .tar, .keys, and in what folder)?Thanks
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Check the 'Ultimate Guide' at the top of this Forum - you will find a 'Where to stick it' entry near the end.
