T_G said:
Hey Phoenix
I suppose as you have been reading a bit more about the Dreambox in this Forum you have detected what is possible or not. To list all would be too boring, but basically there is a lot of stuff that can be seen. The main stuff is Sly Italiya on 13, Taqqilla on 19. Multivision 1 to 8 as well, and Dutch channels +++.
Hey T_G
Is there finger trouble here...
I thought we didnt have Sly on 13 and Taq on 19.
MV 1-8 yes
C+ nordic yes
Or am I paying price for not checking daily, or not having a proper card.
And to underline Stick. After a first week of headless chicken flashing and re-flashing any image I could find, like someone discovering s_x, I stuck to Hydra Lucien despite the naff start-up. Then I just eavesdropped and chatted about it here and in other forums. For the moment, I'll stick with the old bird and learn from her.
And here, for someone just about to flash or re-flash, is a way to learn, that I just know you won't want to try. But it will plod it out:
Get an ftp connection going as soon as you have done the flash erase after flashing.
i.e set IP connection parameters but don't load anything else, nor connect to lnb.
- So in your web browser, type in
ftp://192.168.0.24 or whatever.
- Open the /var directory and open each directory in turn, display the contents in "view -> details" mode.
- Print the window for each directory.
- Write on the paper, "Flash erase:.
- Now scan for your channels.
- repeat procedure for printing contents of directories.
- Write on the paper, "Channel setting"
What now follows is for Hydra Lucien but there is a simiar process for other images
- Download the latest control panel, (exit)
- repeat procedure for printing contents of directories. (gets tedious doesnt it?)
- Write on the paper, "Control panel"
- Download Mary's key bundle. (exit)
- repeat procedure for printing contents of directories. (this one really teaches)
- Write on the paper, "Mary's keys"
- Download a new softcam that wasn't there in Hydra image
- Write on the paper "Name of Softcam"
You now have printed out, the changes that occur in directories when you download important things like keys and softcams.
So when the day comes that the Hydra Lucien (or your fav) software writers accept a lucrative offer to go and work for TPS or C+, and the download site ceases, you have a chance to download keys for yourself and put them where they should go.
