Dreambox Power Cable ?
djc
DM7020-S
88cm Triax Dish
1.8m Channel Master soon to be installed
Doncaster
Hi
Just got my DB5620S from Germany. The Power Cable is a Euro plug and is non-removable, as I have seen people on about using an old Power Lead from a VCR, but can't see how this can be done.
Think I have a Adapter lying around somewhere, where by I can plug the 2 pin into a 3 pin interface. Will this be ok ?
If this isn't ok maybe I'll just have to cut the plug off and fit a UK Plug. A bit disappointed that they didn't use a removable lead though.
Cheers
Chop the plug off and fit a uk plug. Those adaptors arent a terribly good idea.
twag42
Amsterdam,Holland
you can buy a proper uk adapter in most electric shops.
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
Not worth the risk of it coming loose and shorting.
Cut the lead at the plug strip the wires and fit a UK plug like Analogue says.
RedDevil_UK
Retired Mod
Dreambox 7000S, VU+ Solo2, 1.1m Dish, Moteck SG-2100A DISEQC Motor
Rochdale
i agree, cut the bugger off :) get a proper plug on it....
them adapters are a bit wobbly at the best of times....
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
I just bought a whole new cable.
Does that make me a sad-case?
djc
DM7020-S
88cm Triax Dish
Doncaster
Ended up cutting it off and replacing with a UK one.
Cheers
