Dreambox Satellite.xml problem
duncanf005
Diseqc motored dish
Malta
I`m new here. I have a sunray dm800HD dreambox with nemesis image with a motored dish.
I added the Rat Bouquet and when i searched for the satellites in the bouquet there was only 4 satellite(Astra, Hotbird etc...). So with the use of DCC, i used ftp to dowload the file satellites.xml and edited so that i added more satellites and uploaded again to the dreambox. After restarting enigma2 and dreambox When i went on the dreambox manual scan to search for the available services, i noticed that the satellites added to the xml file where not being displayed.
What should i do now so that i can display the satellites from the xml file to the manual scan satellites on the dreambox?
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
Download a new xml from this site.
http://satellites-xml.org/
duncanf005
Diseqc motored dish
Malta
 satellites-xml.org/
I downloaded an xml file from this site satellites-xml.eu but still the issue persists
sonic1
Black Hole Team
How have you got your sats configured ?
We need as much info about your setup and the problem as you can provide, have the other sats just dissapeared overnight ?
Burnham Beech
You need to install the satellites you need into your DM box. Normally this would be done automatically when setting up a USALS system.
Or you can add them manually if you want. The satellites-xml file is just a database of transponders on each satellite, it does not set up satellite positions.
They do need to be both in satellites.xml and configured in your tuner setup. If it is just a motorized dish using USALS go to:
menu -> setup -> service searching -> tuner config -> tuner A
and set it to "simple" and "positioner". Enter your lat/lon and save. After this all satellites in satellites.xml should be available for a manual scan.
smoggy07
To get a new XML over to my DM500s, I use the following method as just FTP`ing the XML to the correct folder rarely works for me:
Use DreamBoxEdit to download all the transponders/channels from your box to a folder on your computer
Once you have done that close DreamBoxEdit, open the folder on your computer and copy + replace your new XML file into that folder
Then reopen DreamBoxEdit and send the files to the DM
Open DreamBoxEdit> Click FTP> Click Receive files from Dreambox (making note of the local directory shown)> Close DreamBoxEdit and open the local directory mentioned in DreamBoxEdit> Copy new XML file over> Reopen DreamBoxEdit> Click FTP> Click Send Files To Dreambox> Click Reload Settings On Dreambox (or reboot Dreambox)> Check the new transponders are listed on the DM
duncanf005
Diseqc motored dish
Malta
Thanks for your reply. I solved the problem stated above but i encountered another one :(.
I have two dreamboxes, dm500 connected to a motorized dish and the dm800 connected to a diseqc 2.0 switch. The diseqc 2.0 switch have connected to it the motorized dish and the Astra 28.2 LNB on another satellite. The DM500 is working normally but the dm800 have only Astra 28.2 channels working.
My problem is that the channels on LNB 2 which is connected to the fixed dish (Astra 28.2 LN:cool: is working normally but the motorized dish which is on LNB 1 is not getting signal to the dreambox. Through Menu-> Setup -> Service searching -> Tuner Configuration -> Alps DVB-S2 I configured that the Astra 28.2 channels gets from LNB 2 and all other satellites (Hotbird, Thor) from LNB 1. I set it that way since i change the direction of the motorized dish via the dreambox dm500 only.
