dvb card and a cam
nuggnu
hi all
i have a dvb sat card for my pc and on the card it has a CI slot on it. can i use these cams i've read about like the magic cam or the matrix cam. what advantages will i get. at the mo all i recive are the FTA chanels.
can i also use this type of setup to program my own cards.
thanks in advance
nuggnu
What make and model of card is it Nuggnu?
PS. Deleted your duplicate post ion other section.
nuggnu
it is a pixle view 3000 dvs card using win dvb to watch tv
Don't know it, does it work with MyTheatre or ProgDVB?
There are lots of different makes of card and many of them are clones, if it is one which works with either of the above viewers, you can install a softcam and put keys direct into the computer.
