EchoStar 23 (will be 45W)
Falcon 9/EchoStar 23 is NET March 1
after delay from 14 march to 16 march
satellite launch Falcon 9/EchoStar 23
5 gmt time
EchoStar 23 will be 67.1°W.
Downlink: 11.45...11.7 & 11.7...12.2 GHz.
TT&C: 11443.0, 11443.5, 11446.5, 11447.0 MHz.
Launch date for the much delayed EchoStar 21 (XXI), is 29 April.
more photo of launch
satellite success launch
Ive split the Echostar 23 posts off the Echostar 21 thread.
Apologies, I mixed up some info, the above mentioned Downlink & TT&C are NOT of EchoStar 23, but of Intelsat 32e/Sky-B1 launched previously. :-ohcrap
Going through various exhibits at fcc.gov however, I still can not be sure of the first whereabouts of EchoStar 23. Most likely scheme seems:
(2) After launch and orbit-raising maneuvers, EchoStar 23 will be temporarily located 67.1º W.L., where IOT will commence for approximately 30 days.
The satellite will then be moved to 86.4° W.L. for 90 days.
(3) Following the temporary operations at 86.4 º WL EchoStar 23 will be moved to its assigned orbital location at 45° W.L.
Alternative scheme:
(2) After launch and orbit-raising maneuvers, EchoStar 23 will be temporarily located at 86.4° W.L. for approximately 90 days.
(3) Following temporary operations at 86.4º W.L., EchoStar 23 will be moved to its assigned orbital location at 44.9° W.L., where in-orbit testing (“IOT”) will commence for approximately 30 days.
So 45°W is the final location (44.9°W is also mentioned and is more likely correct, since Intelsat 14 is already at 45.0°W)
EchoStar 23 has the typical BSS downlink range: 12.2...12.7 GHz circular pol.
TT&C on 12207 and 12208 MHz.
If TLE's are correct, EchoStar 23 now is in an unexpected location!
Now near 44.2°W, moving West 0.15° per day, as if approaching the final location already.
Maybe someone can try to catch the TT&C to confirm this?
Thank you Feedsat! Now the locations seems to have settled at 44.5°W.
** To mod: please correct the title? "will be 45°W" **
Thread title (finally!) changed to 45W. :)
Following the transfer of Echostar's BSS satellites to DISH, since 3 July EchoStar 23 is being relocated to 72.6°W.
That will be next to Nimiq 5 at 72.7°W, already in use for DISH USA.
