Echostar LT8700 Power Supply Circuit Diagram
Likes
5,372
UK South
#3
I ve got one of them lying about in the shed. Amazing that the whole of the analogue industry was decimated by one simple advance in technology
Likes
3,341
Needing a positioner for my Aston Simba, and not inclined to shell out for an interface for my actuator, I unearthed my old SR7600 (precursor to the LT, same power supply).
Being cheesed off with the vagaries of my AD3000's relay-driven positioner, I now use the SR7600 for driving the dish, which together with its solid-state motor drive and excellent auto-peaking is far superior to the (at least my) AD3000.
Don't care about having to operate two STB's - as long as it hits the sat dead on every time I don't need to bother with manually fine tune any more.
Thanks Burnham Beech for pointing us to the circuit diagram - it would have been handy to have had that info some time ago when I managed to locate a faulty pair of diodes after much head scratching. That caged power supply tended to overheat over time.
Likes
1,279
#6
You can leave it if you want, it isn't doing any harm. :)
Likes
gregorian 1.20
Windows Xp
Aalten
#7
Burnham Beech said:
For anyone interested - files in PSP format (PaintShopPro)
I:Johan have/hase doawn-load it,but now i see i have not Paint shop Pro.Is their an other way to open it?!
Mvg:Johan
Likes
5,372
UK South
#8
You could try the Ivanview software, free trial download
_http://www.ivanview.com/ivanview.html
Likes
gregorian 1.20
Windows Xp
Aalten
#9
Oké,but i have it done with an other system on my Pc.
it was not,what i was saer-ching,i need to nowe what pins
(from the 8)i must used,fore the:max232 interface
Mvg:Johan
Likes
3,341
In the absence of a schematic you need to trace the pin connections to the receiver RS232 driver. If it's a MAX232 dual driver, check this diagram. Pins 13 and 14 (RX/TX) or 7 and 8 will be the ones going somewhere to your connector pad.
Likes
gregorian 1.20
Windows Xp
Aalten
#11
Hallo Llew:wheir did you find it?and wheir good i translete whot you
wrote,because my Englis is a little bit(so,so)
Thank you any-way to helping méé,with my problem
Mvg:Johan
Likes
Echostar LT-8700
Jordan
#12
hi ,
this is my first time in the site, I wonder if any one can help in using the poer supply of the old echostar LT-8700 power supply to be used separetly as an external power supply for some projects. thanks
Ramzi
Likes
3,341
May not be a good idea, as it's designed to supply specific voltages and current loads to the receiver. However, if the main supply voltages are what you need to run a project, the load taken from the supply may be within limits of the stated output from the supply to get you running.
