emu firmware for KAON 570H
sat_freak
Likes
helppppp!!!!!!!!!!
i have a KAON 570H receiver with a PVR hard drive...
s/w: 13.05.01
h/w: 13.41.6d
loader: 5.1.6
c.a: 2.1.9
pvr: 1.6.0
im trying to get a software EMU in that will sort out the usual 6-in-1 and nagra stuff but no joy.
im using a KUP226user and a ksc-570hz_hw13[1].41.6d_sw13.05.03_conv file, both from la-cafetera site..but when i try it says receiver mismatch....
it may be due to my receiver bein 570H and the file is for 570HZ......but the hardware version for both is the same : 13.41.6D
so to the question, guys: is there any such file for my particular model??? and where can i get it?
or could i jus manipulate some parameters and force the file into the receiver somehow?
please point me to the right direction thanks
Likes
Hi I got the same kaon570h and I wanna to get software to accept nagra key and all other key as well,how and from where can I get it. pls
dishead
Likes
sat_freak said:
helppppp!!!!!!!!!!
s/w: 13.05.01
h/w: 13.41.6d
loader: 5.1.6
c.a: 2.1.9
pvr: 1.6.0
use kup 230 engineer patched , press space-bar to get it in engineer-mode
select the soft , switch receiver off and on to download.
if soft is inappropriate(machine doesn't start up again) don't worry ,try another one (bootloader will not be affected)
after successful download machine might display "NOCH" (no channels)
just press "OK" button on the reveiver and your precious settings will be back.
you also may go to "system settings" and set any possible setting to "unlocked" or lock "off" to activate the e*u
for key-edit press yellow,blue,green,"menu"
cheers dishead
