EMUpgrade v2.21 problem .. need help
Likes
satellite software
uae
#1
Hi
I connect my laptop to my receiver through :-
1- USB to RS-232 cable .
2- RS-232 female/female cable (9 pin) .
When I press "Start" in EMUpgrade program and I turn on my receiver I saw the dwonlod windwos in my receiver. But the progress bar on EMUpgrade not work, I think this is mean connection faild .
What Can I do?
Is there anybody use his laptop to update the receiver software? Tools plz.
Notice: Receiver : StarSat X-150 D Plus.
Thanks,,,
DeepDiver
Likes
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
#2
Is the cable OK ?
The connection must be
2---->3
3---->2
5---->5
Likes
satellite software
uae
#3
Hi DeepDiver
I'm already check the cable and it's ok.
But I use USB to RS-232 to connect my labtop with the RS-232 cable which is connected directly to the recevier.
Is there any problem when I use USB?
thanks..
dximxi,,
DeepDiver
Likes
#4
Indeed this may be the problem. Similar questions have been posted in the past on this forum. It seems the connection does not work when any kind of adaptor is used, or a port different from serial.
Likes
satellite software
uae
#5
I tried another rs-232 cable and it starts download . But it's download only 5oKB of 700KB and stop.
Thanks,
Topper
Amo Amas Amant Admin
Likes
3,243
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#6
Thanks,
I would suggest you do a search on the forum as I am sure there has been a post before that tells you to clean the old patch from the StarSat X-150 D Plus before re -flashing...
