Eurosport in english
sky888
does anyone know where i can find eurosport in english. I have a MM and fun card, will I need it for that channel?
Have you got a spare analogue receiver ?
19 East is still with Eurosprt on its list, 7.02 MHz is the English subcarrier, but this is split about 50/50 with German nowadays
sky888
I have got a spare analogue recevier, but what u are saying is that I can't get it on digital?
juhani
Visit site
finland
Eurosport is on Hotbird 13 east, 12558 V, 27500,3/4.
I use 6in1 files
Juhani
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
How do I change the german to english? I got MyTheater and when I look at the properties of Eurosport there are all sorts of numbers in the Audio etc.
Is it possible?
TG
If you right click on the channel, the audio pid will be listed at the bottom of the list (no need to go into properties), if there is only one listed, then that's yer lot. :)
The analogue audio carrier for English is 7.02 only, it may be the system is still providing you with both left and right channels as outputs unless you can select narrow band mono on the receiver
T_G
Yeah, that one I already figured out, you know me...if there is something to change on a setting I will try it. But I was hoping I could somewhere put in a magic number or code in the audio.....never mind. Thanks for the info though!
