Firefox speed up procedure
I know that Marts posted this a year or so ago, but if you have broadband, then this will speed up page loading.
mhku
TM Nano ~ sg2100
Midlands
I've found Firefox is significantly worse since doing this. I normally have half a dozen to loads of tabs open at any one time.
Now, if I open 6 tabs at the same time e.g. new posts, all pages hang for about 30 seconds. Even had a few crashes.
I've seen this but not tried it yet:
_http://fasterfox.mozdev.org/
TigTex
Ouralis Evo3
Dreambox DM800se
Portugal
Don't enable pipeline because there are lots of servers that don't suport it.
The result will be pages that never end opening.
Some good tricks can be found here _http://w*w.extremetech.com/article2/0,1697,1854234,00.asp
BarMoo
Post Meister
2xPace 430N, 1xNokia MM9800, 1xNokia 80cm Sat Dish, 1xGibertini 120cm, Big Fat Furry Puss
Berlin, Germany.
I am not claiming anything here - BUT - I swear that FF 3 Alpha 3 is fast - like faster than my Maxthon browser ;-((
Check it out/download here
Apparently all the new stuff [at this alpha stage] is back of house - but try it anyways ;-))
Thanks for that Mark, it does seem a little quicker, certainly with javascript viewers etc and the page loads are really snappy.:)
TigTex
Ouralis Evo3
Dreambox DM800se
Portugal
That browser it's firefox 2 alpha 3. No firefox 3 a3.(at least, it's what I see)
Seems like on firefox 2.0.1, pipeline can be safely enabled. It gives you an excelent speed improvement.
Write about:config and search for pipeline. Change it from false to true.
I also recomend you to change the network max conections to 48 and max connections per server to 28. I have a 4mb conection. Works great with me
Yes I've been using pipeline since I downloaded v2, but must confess this new version is just that little bit faster. :)
johnnysuttie
AMD Duron 2500+
Pace ds810xe hd satellite
barnsley
thanks for that... noticed the speed change.
