First Setup - PLEASE HELP!!!
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
martz said:
thanks, i'm so happy now lol
Well done martz congratulations, but just one word of warning as soon the trees will have leaves on them and it is possible that these COULD affect your signal or indeed block it altogether.
Lets hope it doesn't
Rob
martz
Thomson Sky+ PVR3, Pace 2200 Sky box, Zone 1 Triax minidish with Thomson Quad LNB, 1m Gibertini and Technomate TM-1500CI+ Super (Patched) 1metre Gibertini at Astra 1 19.2°e
Barnet, North London
i'm not asking for any links or anything but does anyone know if there is a patch available for the SL35, just so i don't go searching for hours for no reason.
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
Well done martz good to see you are sorted!:-bighappy
blue1927
Silvercrest sl65, Phoenix Apollo 2CI MC
Caerphilly, UK
martz I don't believe that there is a patch for the SL35 at present. However, take a look at this forum. Cheers Blue1927
http://comagforum.zapto.org/index.php?act=site
martz
i'm thinking of getting a technomate tm1500+ super, and an art card, on the art transponder i have managed to receive the IQRAA- ARABESQUE, this is fta but shows the same signal quality and strength as the art sport channels - Strength - 75% Quality - Between 35% and 51% but doesn't go blocky at all, does this mean i should be able to receive the art sports without it going blocky? considering my setup(if i get a technomate)
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
your really getting the bug
wod
yorkshire
you should be fine they usually say 80cm dish for hotbird but your recieving it so i doubt you have any problems
martz
i sure am, i've been interested in satellite tv for a long time but my parents only recently let me get my own dish (had sky since 99) and it's gone on from there, and my parents are so impressed i've managed to install it all myself (except drilling the holes) and it's my birthday on friday so should get some cash from that and some cash from ebay sales and i can afford some decent sat gear. also i used to get blockiness but i moved the dish up about 10cms on the mount and now i get perfect signal on all channels, must have just managed to get it pointing over the trees or through a gap lol.
wod
yorkshire
very good, i jumped into it too quick and got setting up offset lnbs and alsorts before learning the basics
yes next get a patchable reciever something like a technomate 1500
martz
that's what i was thinking of, maybe after my bday next week
martz
I dug out this old dish from the loft and I want to use it like Analoguesat uses his tyre dish, i want to take it to my nans round the corner when i stay there, the only problem is it doesn't have an lnb collar and the one i have on my 57cm is the same size as the hole, what can i do to get the lnb in the correct place?
I know it looks rusty in the pics but its not really that bad.
The actual pole measures 2.5cm across
Rob
Essex
I would think you might need a larger dish something nearer 80 cm, but try your dish first and see what happens.
If you do need a larger dish it won't take long to fit one up.
But if I where you wait before you start splashing out money on cards and receivers, after all the football season is drawing to a close now, and when the trees are covered with leaves you might have no picture at all.
Play with what you have and see if you can still get a picture in the summer.
