Hi i want to try the multiboot option in flashwizard 4, i'm using a usb flash disc "Olympus" (with a Fujifilm 16mb XD card) and i can't mount the disc from flashwizards configuration panel, when opening telnet and typing
mkfs.ext3 /dev/scsi/host0/bus0/target0/lun0/disc or part1 (at the end) the usb disc formatts successfully then i can mount it to any place like /var/mnt/usb, /mnt, /dev/usb but after i mount the disc to one of these places i still cannot make flashwizard detect it, i guess flashwizard wants to mount my disc to a place like /mnt/usb which i don't have and can't create because of the permissions. And also when i try to format the disc from flashwizards configuration, it shows that the disc is formatting but at the end it says Unable to format and mount the usb stick!.
If you have any suggestions please reply me! :-)
P.S. i'm using Dreambox 7000-S with a crossover ethernet cable.
