mickkeay
- Jun 20, 2008
- Age
- 66
Penta 68cm
Moteck SG2100
Fortec Star Passion HD
- Brighton, Sussex
apologies for re-post (I put it in original thread)
Many thanks guys - all up and working now. Bit of trouble finding that Thor but got there in the end. I fitted a new 68cm penta in the end. It is fitted on a flat roof (ashfelt / gravel etc.) I leveled then screwed a 2 foot square piece of weatherproofed blockboard onto the roof and then screwed a 1m Patio pole into that. My only concern is the base of the patio stand is only about 20cm square and the dish and motor are quite heavy. I think in time the wind on the dish will loosen the screws and I will be back up there. Any suggestions? (I did toy with the idea of using a concrete paving slab - so I could use some expansion bolts in the slab
I also fitted a 4way LNB so I could run another receiver later but wondered the best way to connect the cables? Ideally I would like for either receiver to have the ability to move the motor (but not at same time obviously) Is that possible - splitting the motor input two ways? Would it get confused where it was? Or should I just leave one receiver passive and just connect it directly to the second feed of the LNB ? Thanks again Guys
