Hedley
- Mar 25, 2007
- Age
- 66
Tecatel 3.1 dish
Pace 2600c1 receiver
- Fuerteventura
Hi Fringe, You are correct I meant quality. I think your readings are mis-leading as I suspect your box does what Sky boxes do when you check signal strength and quality and default to test a north beam signal hence the flattering numbers. The best sky box for fringe areas is definitely a pace 2600C1 which looks like the 430 but has a much finer tuner. As you say we may never know the reason for the drop of signal at night down here at certain times of year but have to work around it.
Like you my dish is well secured but literally just pressing the dish on one side is the difference between getting a signal and no signal, it is that fine!! Hence anything you can do to optimise your signal will see big results. I do recommend the tensioning wires are you can then play around to get the best signal, best in the morning as any difference shows up more easily. With the tensioners best get inox (stainless steel) ones as when the signal falls away in the Spring you will be able to adjust your dish without scraping off the rust. Let us know how your realignment goes. It is very much trail and error but worth it in the end for a home from home, UK TV, in the sun!!
