foretec star passion + will not restart although power is on?
1jayjay
foretec star passion + hitachi hd 42"
uk
hi al,l foretec star passion + box shows power on as the blue dial is alight but there is no name blazing in the display nor will it connect to my hitachi hd hdmi capable tv.....i have had these connected for more than two years . this morning before this issue i tried to add radio caroline to allow the signals for epg and set up dummy transponeders vpid and apids on eurobird 9....then reset by turning power off and on and now nothing .....help please.
My stb is unable to upload any updates via usb so this system had no updates since being sold to me.
Failure to start is almost certainly a power supply problem. See this sticky for help -
_http://www.satellites.co.uk/forums/fortecstar-hd/165101-my-fortecstar-passion-dead-just-asleep.html
1jayjay
uk
thanks , i shall look at the option set out on the other thread.
regards,
jay
1jayjay
uk
i have removed the defunct capacitors 2x 10v 3300uf +105'c but maplin no longer stock these and i cannot find any of this shape or make .they look like gasometers on legs and have printed on them JH cd263 and w-8........do i have to get this ytype specifically ? could they have been upgraded since first shipped in the sat box.......these may sound dense questions buti am completely new to this and cannot afford to buy a new box .
all help gratefully recieved
jay
Farnell have a selection - _http://uk.farnell.com/aluminium-electrolytic. Use the filters in the chart to tick 3300uF, 10V only. Scroll down in the results. You need 105°C radial leaded. Size is shown in the chart, just choose one with a footprint that the power supply will accommodate. You may need to purchase more than the two you require, usually five.
1jayjay
uk
Thanks Llew but farnell have a minimum spend on cards of £20 . I live near tottenham court rd in London....any shops near me that you know of ?
regards,
jay
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ebay to the rescue ...
how about 10 for a fiver ???
check 110595603985
105 degrees high esr ..
should do the job nicely providing they physically fit ..
Dimensions are :-
Dimension 12.5mm x 25mm
Lead spacing 5mm
rgds
VS
regards,
jay
Used to be loads of components shops in or near that area in my day, now mostly Dixons and the like. Vipersan's suggestion seems the best idea. I have the basic Passion box which has a different power supply. Without checking mine, I believe the capacitors are a tight fit amongst the other components, so if the capacitors you buy are too wide, you could get away with extending and sleeving their leads so they stand out from the board. Just make sure you have the +ve and -ve leads the correct way round when you fit them.
Cricklewood Electronics hold a component stock, may be worth popping across to there.
Ah yes, forgot about them Rolf. The 3300uF 16V electrolytic there would be OK, depending on size - some higher voltage caps are smaller in profile than others of the same value, depending on manufacturer.
1jayjay
uk
thanks guys for the suggestions VS all bought and awaiting delivery in tghe meantime i have bought a bush box from argos which i must say was the easiest thing to set up...less than 10 mins although a bit of hassle adding non-freesat channels....but this way we will not miss any of the olympics and the box can always be returned or keep as a back up.
1jayjay
uk
hi llew and others, where would i found out about +ve and -ve fitting and what are sleeves ? the parts i bought are too wide (doh)
The +ve (positive) lead will be the longest one, inspecting your new capacitor. In any case, the capacitor will be marked '+' down the side of the capacitor adjacent to the positive lead.
A sleeve for the leads can be made from any insulation stripped from a piece of cable or wire, so that it can be slid over each capacitor wire in order to prevent electrical contact with the other wire or other components' exposed connections.
