forget password for my receiver! help!
ikuwara2000
I got hyundai HSS-800CI receiver. How can i reset password on my receiver?? does anyone know??
ikuwara2000
hmm...my receiver seems dun have factory reset button.... is it have to use null modem cable to tweak the receiver?
philip24
Visit site
It's usually in one of the On Screen menus, assuming you can get that far without a PIN.
Do you mean that YOU have changed the PIN since you acquired the box?
A factory reset will restore the PIN to its initial setting when it was manufactured, and that PIN should be in the manual.
ikuwara2000
Yes i have changed the PIN last two years when i have the box... I can'tt find any factory restore on the Menu screen... Is that firmware upgrade will restore the PIN to default PIN??
ikuwara2000
I have lost my manual... Okay thanks philip for helping me up. I will try to email Hyundai...
samer
try 0325, and let me know if you succeeded
Rolfw used to have one of these
I think a firmware update is preferable to looking through 9999 codes but the I would ask Rolf first
Been trying to speak to the guy who has it now CH, but he is away. You can get the latest firmware (there are two versions for this model and only one will work) from Hisat, but this is obviously a last resort.
