fortec star beta keys help
Likes
Technomate 1500ci+super
england
#1
hi all, just wondering if anyone knows how to put keys in the beta,
i know how to get the keys section up, i know that a key has to be split in half to go on two lines. What i dont know is that at the begining of "each" line there is a 6 digit index code and a 2 digit id code, what do i do in these sections and is it the same for both lines of the key..
please can somebody help. without knowing how to do this the patch is pointless..
Robbo
Likes
5
Gravesend,Kent,UK
#2
I have put them in before, but I don't have that receiver anymore. Can you post a screen shot with the keys blanked out? I would remember then.
Keys must be blanked out.
Likes
england
#3
hi its like this
index id
01 xxxxxx xx xxxxxxxxxxxxxxxx
02 xxxxxx xx xxxxxxxxxxxxxxxx
03 xxxxxx xx xxxxxxxxxxxxxxxx
04 xxxxxx xx xxxxxxxxxxxxxxxx
and so on in all types ie nagravision, bliss, seca. etc
index is the set of 6 digits, id is the set of two and the 16 are half of the key due to keys being twice as long. thanks
Robbo
Likes
5
Gravesend,Kent,UK
#4
Right,
its coming back a bit...
As far as I can remember, I only did the d+, (got it working, then gave up as it was too much hassle)
The 2 digit boxes were already filled in, so I didn't have to find out what they should be. All 4 were definitely different though. I think that if you scroll to the correct ID, they should already be filled in for you too, by the patch.Come to think of it, all the keys and the IDs were too. (but with out of date keys)
Key columns:-(16 digit)
The first 2 lines are the for key 00, the second 2 are for key 01.
1st Column:-(4 digit)
I think these were all the same. It was either 4001 or 4101 (for d+)
2nd Column:-( 2 digit)
Really not sure on those.
Might have been 00,10,01,11 or 10,11,20,21.
Might have been neither, sorry. I don't have the receiver anymore so I can't check.
I am sure that there was a list in there somewhere and you just selected
the correct provider ID, and all you had to do was edit the actual keys,
everything else was already filled in.
Edit.
Pretty sure it's
004101-00-xxxxxxxxxxxxxxxx
004101-10-xxxxxxxxxxxxxxxx
004101-01-xxxxxxxxxxxxxxxx
004101-11-xxxxxxxxxxxxxxxx
for d+
Don't think you can get much else.
Likes
england
#5
thanks robbo71 i'll give that a go. it was the second colum that was confusing me, the 1 with the two digits in.
thanks alot for your help
Likes
england
#6
still cant get d+ keys to work. does anyone have this reciever that knows how to put in these keys... if i look through d+ show up in seca not nagra.
now i know why you dont have this reciever no more robbo lol
Likes
england
#7
also there is only 3 lines for d+ then its another couple of packs then it goes back to d+ but 3 lines again in the seca list of keys...
d+ xxxxxx xx xxxxxxxxxxxxxxxx
? xxxxxx xx xxxxxxxxxxxxxxxx
? = other package names or channel names
Robbo
Likes
5
Gravesend,Kent,UK
#8
I think the support for it has been completely dropped now its no longer on the A****r-soft site.
My key list certainly didn't look like that!
The words 'flogging' and 'dead horse' spring to mind.
And if you did get it working, you would only get d+ ( probably won't last much longer either) and manual key edit only. I tried it a couple of times, then realised I couldn't be faffed fiddling, so I went straight out and bought my technomate. I believe the basic model is only £50-£60, and more support than you can shake a stick at on als*t. Which I expect you've seen.
Likes
england
#9
cheers robbo for all your help. i just wanted to get it working for upstairs but i think i'll leave it. ive got the TM 1500ci+super downstairs and thats great so probably i'll get rid of the beta and maybee get another TM for the upstairs..
thanks again for all you help and support on this thread
