Fracarro Penta Satellite Dishes
Rob
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Just seen one of these on E-Bay (85cm) and they boast that they are better than a 1 metre dish.
What with the corner's missing I find this rather hard to believe, what do you think.
L
Likvid
Stockholm, Sweden
You don't need the corners, the biggest concentration of signal is in the center of the dish so they cut the corners and made it bigger in the center parts.
I would be very surprised if it were better than a 1m.:)
Topper
Topper
Amo Amas Amant Admin
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
Believe it when I see it Admin :-rofl2
would love to know how one makes it bigger in the middle though:cool:
L
Likvid
Stockholm, Sweden
If you added the corners to the above dish you would have approx a 1m dish, by removing the corners they made the dish look smaller and perform almost like a 1m dish.
Topper
Topper
I am aware of dish theory which is why I was questioning the statement
about making it bigger in the center parts
, I do not understand what you mean that is all
Cant see how you come to that conclusion, as the overall diameter would still only be that of your average 80/90cm dish.
Frequency Range 10.7 -12.75 GHz
Dimensions 775 X 775 mm
Offset Angle 22.1 degrees
Efficiency > 70%
Gain at 10.95GHz 39dB
Cross Polarisation on axis >38dB
First Side Lobe <-34dB
Nosie Temperature 40degrees K at 30degrees Elevation
F/D ratio 0.7
3dB beam width 2.2degrees
LNB Clamp 23-28; 40; 60 mm
Elevation angle Maximum tilt 60degree - Base 41
Mast clamp 35-80 mm
Material Steel
Supporting Bracket Material Steel zinc treatment
Wind load at 150Km/h 81 Kg
The hirschmannFesat 85 cm claims a slightly lower DB gain and I would be slightly more inclined to believe their figures, as the dish is far better built than the Fracarro, which looks a tad on the flimsy side, particularly the AZEL bracket.
Reflector Ø: 0.85m
Colour: Light Grey
Frequency Range: 10.7-12.75GHz
Gain at 10.95 GHz: min. 38.3dBi
Half-value aperture 3 dB: 2.1º
Offset angle: 21.1º
Noise temp. at 30° elevation: 40 K
G/T: 22.3 dB/K
Mount for mast Ø: 40-89mm
Adjustment range, elevation: 15-45 degrees
Wind load: 600 N1)*
Width/height: 85.5x90.5cm
Weight: 9kg
Packaging dimensions: 90x95x24cm
Scope of delivery: Reflector with back/supporting arm with feed mount. Mast mounted with el/az adjustment
* Wind load calculated in accordance with EN 50083 Part 1 with q = 800 N/msq and c = 1.2
