After some testing i have found the following boxes work with pid entry
DION VSTBAW09 (not + version)
DION STB1AW09 (not + version)
its best to buy new if possible and only from tesco on ebay!
duwie said the box STB2AW09 does pids but only if its NOT + version from what i can tell for that particular box.
it seems the + is for channel zero services, where the firmware is stripped of anything decent and you then have more ram for channel zero (which is a load of crap btw)
there are alot of refurbished ones on ebay so be careful that your not ending up with the + versions.
as i speak there are 4 DION STB1AW09 left on ebay with tesco, carefull as theres a + listing aswell which are no good from the same seller.
untested: DION VSTBAW10
would somebody like to test one!?
hope this helps somebody like me lol
Spinifex.
