FTA box help required
M
mulls74
Likes
80cm fixed dish
Lingfield, Surrey
#1
I am looking for a cheap FTA box to use at a holiday home in Tenerife. At the moment, the flat has an ancient digibox but no viewing card so it is a real pain to listen to FTA radio or TV channels on 28.2 because you have to go to Other Channels and the memory keeps wiping etc.
We have no intention of paying for a murdoch subscription so I am looking for a decent, cheap FTA box to replace it. Can anyone recommend a good one at a low price?
Thanks in advance.
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#3
For £99 Maplin have a full FTA satellite system...
_http://www.maplin.co.uk/module.aspx?ModuleNo=43113&doy=14m12
or the Lidl receivers pop up on eBay often (Comag or Silvercreast) don't think they will have then again till early 2006.
P
pgh13
Likes
379
Midlands UK
#4
Wizard satellite have a Fortec FTA at 50ukp - h__p://www.wizardsatellite.co.uk/
M
mulls74
Likes
80cm fixed dish
Lingfield, Surrey
#5
Thanks - very useful. Would a fortec be better than a comag sl 65? I see a few of these on Ebay for around the same price.
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#6
Sure the Comag can be 'patched' not sure if the Fortec can.
Do a search here for 'Comag' and you will get a lot more information ;-)
J
jacko
Likes
12
tenerife
#7
hello,from tenerife.
i would go for a technomate 1000d for about 75 pounds.
have bought quite a few of these for friends and family.
easy to patch.you can pick up loads of channels with
with a 60 cm dish.
i
W
whatsthis
Likes
DM7020 Screambox
MAC OSX & windowzz 98SE
Gemini
1664 on tap
13°E
#8
If you just want a cheap digital box pop along to your local DIY store. They're about 50 euros here in france and you can get all the BBCs and ITVs and the radio in digital.
No CI Cams etc just a basic simple box. Take a look at Kelkoo.es and enter FTA or numerique or what ever it is in spanish.
T
the_wizzz
Slightly biased Technomate Seller
Likes
go for the best...technomate tm-1000d super
it's the only receiver out of the ones everyone has said which has hardware blind search which is very fast....has regular patch....very easy to use menus etc....just read my review in the reviews section
