Gemini 1.03 problem
DHeart
DHeart
Speed Freak
Likes
Dreambox 5620, Dreambox 500Si, with universal 3 LNB's and 2X 80cm dish.
Portugal
#1
Does anyone tested the new version?
I have. It crashes, or the problem is mine.
I have flashed it into my DB and, when it starts, it doesn't display any image on the tv set. But it responds to the remote control, because i see it on the DB display.
Can anyone tell me if it's my mistake or problem with the image?
I went to the IHAD, to get it and the newcamd 5.28.
Now i have the 1.02 version, and it work extremely well.
T
td03-5
Likes
Hi Dheart,
You could try installing 103 again, sometimes a problem seems to occur with these new images and a re-installation cures it!
On the other hand, if 102 is doing all you want at the moment then be safe and stick with that.
73 & good luck.
