blademedia
- Jul 29, 2016
- Sky
- UK
I manged to remove the armature and will give it a clean. When I pulled it out of the sleeve, there were two spring loaded contacts that make a contact with the communicator bar, one of these popped out on its slider and it looks a tricky job to manipulate it back in there. Does the armature sleeve disconnect from the cog housing? There are two small screw heads at the bottom of the armature sleeve, if I can get the sleeve off I hope it will make it easier to get it all back together.
Thx
Hi D, the spring loaded contacts are the bushes, all the unit is pressed on the rod, a special tool is need to remove it, but no need too,
The parts you need to be interested in is communicator bar and bushes the things like magnets on springs, photo of the bushes might help/how much is left of them ?
The small screw should help you refit it, there's a few different types its hard to say without having hands on
@blademedia,
Sorry for the dumb question but which parts are the bushes, are they the 2 x semi circular shaped magnetic parts that wrap around the armature?
Thx
As above D.
